YM 180 transmission fluid
   / YM 180 transmission fluid #1
pennwalk
Veteran Member
Lancaster PA
Yanmar 186D
I am working on a YM 180. Can anyone tell me how much transmission fluid it takes?
Chris
   / YM 180 transmission fluid #2
I can tell you a ym155 holds 2.5 gal. I can tell you a ym226 holds 14.7 qts and a ym226d holds 15.3 qts. Guess the ym180 is somewhere in between?
   / YM 180 transmission fluid #3
Add till it reads full on the dipstick, then start and recheck the line...
   / YM 180 transmission fluid #4
its a smaller size to a 1500 and they hold about 15 litres so i would say about 12 litres for a 180.
I have 3 gallons in it now and it isn't all the way up to the mark. Do you screw the dip stick in to take the measurement?. My main tractor is a 186d. I got this 180 for parts but it looked too good so I am trying to get it running. There are enough differences that the 186 manuals aren't very useful.
Chris
   / YM 180 transmission fluid #6
After puzzling over several Yanmar manuals I concluded what they meant was don't screw in a threaded dipstick, but do push in one that slides into a rubber grommet.
I don't think there are many points where the difference has any significance.
   / YM 180 transmission fluid #7
I know on my tractors, the trans fluid is for the rear diff and the trans, so it takes quite a bit.
None of my tractors have a dip stick, they all use a weep hole, so it takes the guess work right out of it.
   / YM 180 transmission fluid #8
Chris
I agree with California, I have 3 different manuals (not the 186d) and all of them say check without screwing in.
I have started marking tractors with the amounts of fluids they take when I can figure out what it is supposed to be. It is sort of a pain to use trial and error and end up having to drain a little off when I miss. Fluids are getting expensive. I wish all vehicles came with fluids and air pressure marked on them.
Chris
I picked up a service manual for the 180 today. For future reference the 180/180D takes 13 liters or 13.7 quarts.
Chris
2012 Porsche Panamera Hatchback (A50324)
2012 Porsche...
Backhoe Attachment (A50322)
Backhoe Attachment...
UNUSED SWICT 84" QUICK ATTACH BUCKET (A51244)
UNUSED SWICT 84"...
UNUSED AGT XZ20R EXCAVATOR (A51243)
UNUSED AGT XZ20R...
2013 XLR THUNDERBOLT 35X14 5TH WHEEL CAMPER (A52472)
2013 XLR...
2020 GENIE TZ-34/20 TOWABLE MANLIFT (A51242)
2020 GENIE...
