YM 1601
   / YM 1601 #1
professor
jackson tn
Allis Chalmers 416S John Deere LX280, John Deere Z225 zero turn yanmar 1401 , Oliver 550 Special, Oliver 75 Lawn Tractor, New Holland 3930 4WD, Mitsubishi BDF2 Dozer
My brother-in-law just purchased a 1601 from an importer. It is very sharp with original paint etc. It is my understanding that this tractor has a three speed settings with the 1st the lowest three speeds, 2nd 4,5,6 and the 3rd with 7,8,9 and a reverse in all three settings. When I tried the 1st group doesn't work. The 2nd and third work perfectly. The pto and hydraulics work perfectly. What is the problem or does it only have 2 range settings with 6 speeds forward and 2 speeds backward?
   / YM 1601 #2
The creeper gear must be locked out. There will be a long bolt in front of the range selector that keeps it from going into creeper gear. Remove the bolt and it should go in gear.
Danny
Parker Equipment Co
   / YM 1601 #3
I agree with Danny, but with the creeper gear you should have 4 ranges, C, 1, 2 and 3. Sometimes you can get the range shifter between gears and it becomes as a neutral, so consider that as well.
UNUSED AGT TSOCPF48 MAST W/ 48" FORKS (A51248)
UNUSED AGT...
2022 BOBCAT T66 R-SERIES SKID STEER (A51246)
2022 BOBCAT T66...
1/2'' Wolverine Universal Quick Attach Mount Plate (A51573)
1/2'' Wolverine...
UNUSED FUTURE HYD THUMB CLIP (A51248)
UNUSED FUTURE HYD...
WHYNTER ARC-102CS PORTABLE AIR CONDITIONER (A51248)
WHYNTER ARC-102CS...
2012 Morooka MST1500 Crawler Carrier (A52384)
2012 Morooka...
