YM 1510D 4WD Front Axle and Bearing needed
   / YM 1510D 4WD Front Axle and Bearing needed #1
PearieEh
Yanmar 1510D 4WD
I am looking for the front axle and bearing for a Yanmar 1510D. The 4 bolts came loose and the broke the axle and bearing. If anyone has a front end final drive both the right and left side are the same.
In the attached picture the axle without the bearing is the broken one, right at the spline where the bearing is pressed on.
Any assistance would be greatly appreciated.
Thank you
   / YM 1510D 4WD Front Axle and Bearing needed #2
Welcome to TBN!
I see the broken bearing, but what is wrong with which axle?
Where are you located? It can help folks here help you more specifically.
All the best,
Peter
   / YM 1510D 4WD Front Axle and Bearing needed #3
A detail relevant to your parts search: YM1510D and the US YM186D are identical in many respects BUT they didn't use the same front axle assembly. Some internal parts may cross over but don't count on it.
   / YM 1510D 4WD Front Axle and Bearing needed #4
   / YM 1510D 4WD Front Axle and Bearing needed #5
Looking for a stub axle? You are? I'm looking at a bearing in really bad condition. Nothing wrong with the Axel?
   / YM 1510D 4WD Front Axle and Bearing needed #6
Welcome to TBN!
All the best,
Peter
@PearieEh I see the issue with the axle now. My apologies. It looks very repairable. Do you have a local machine shop that could align it and weld it for you?
All the best,
Peter
   / YM 1510D 4WD Front Axle and Bearing needed #7
Repair what! The bad spot now I zoomed in. The inner Bearing collar is going to cover most of if not all of that corrosion. JB. weld it.
   / YM 1510D 4WD Front Axle and Bearing needed #8
Look carefully at the end of the splines on the broken axle, where there seems to be a bend in the axis of the splines to the axis of the shaft.
I'm quarterbacking from miles away, but it looks as if the distance from the straight edge to the splines is different, suggesting to me that the spline portion is bent relative to the rest of the shaft. (Great photo @PearieEh!)
All the best,
Peter
   / YM 1510D 4WD Front Axle and Bearing needed #9
All the best,
Peter
Look even closer and you see that the spline section is completely separated from the shaft.
   / YM 1510D 4WD Front Axle and Bearing needed #10
The male side of the Axle shaft will be held straight and tight from the Bearing and the Gear. My guess. It looks repairable but personally I wouldn't worry to much about it. The 1500D is only 1433 Lbs... the whole tractor. FEL. pressure on it maybe a problem on that little tractor. No mention?
JOHN DEERE 850J LGP DOZER (A52472)
JOHN DEERE 850J...
2016 FORD F-150 (A52472)
2016 FORD F-150...
2015 INTERNATIONAL MA025 (A52472)
2015 INTERNATIONAL...
CAT 973 (A47384)
CAT 973 (A47384)
New Holland 55 Pull Type Rake (A51573)
New Holland 55...
BUSH HOG 2820 LOT NUMBER 128 (A53084)
BUSH HOG 2820 LOT...
