ym 1500 transmision hydraulic oil
   / ym 1500 transmision hydraulic oil #1
thedart
australia
ym1500
hi
new in the forum. does anybody know what type of oil and how much
i shuold put back in my yanmar 1500,after losing it all because of some cut
in the pipe
no FEL on my tractor
thankes
   / ym 1500 transmision hydraulic oil #3
Right at 4 gallons. I use Walmarts Super tech hydraulic/transmission fluid. I have used Travelers brand from Tractor Supply. Main thing is to use combination hydraulic/transmission fluid. I would advise cleaning your suction strainer at this time. Located here. Yanmar Tractor Parts: HYDRAULIC_SYSTEM
thankes for reply
can you tell what the viscousty should be ? we have got different oil brands here
   / ym 1500 transmision hydraulic oil #5
thankes for reply
JD-303 or Equivalent..
   / ym 1500 transmision hydraulic oil #6
I see you are in Australia so I don't know about brands. Yanmar specified Universal Tractor Fluid which is available from several brands, and will be sold anywhere that has agricultural customers. The original UTF is labelled to meet Deere 'JD 303' specs and that is all you need in a moderate climate. There are also later, broader-temperature spec fluids available now but Yanmar doesn't mention those in their 1970's manuals.
Here, UTF is sold in 5 gallon pails. (~20 liters). Your YM1500 should take about 3/4 of that.
thankes
i'll probably go to jd dealer here and get it from there.
   / ym 1500 transmision hydraulic oil #9
Ha i can use litres now, from a fellow Aussie. My 1500 WITH a loader took about 16 litres, no FEL i imagine it will take about 12 or so litres. Cheaper to buy 20L anyway. I used Peak Oils Hytrans and it has been good.
   / ym 1500 transmision hydraulic oil #10
Hello everyone, not only new here, but brand new to tractor ownership. I have a Yanmar 1500 (1979) I just bought and am in the process of changing the fluids and was wondering about changing the oil in the gear box. Does it take standard 80/90 gear oil? Any advice is much appreciated
UNUSED ECHO CS-4010 CHAINSAW (A51247)
UNUSED ECHO...
2014 Ford Explorer AWD SUV (A51694)
2014 Ford Explorer...
UNUSED RAYTREE RMDM725-72" DRUM MULCHER (A51248)
UNUSED RAYTREE...
2015 DODGE RAM 1500 CREW CAB TRUCK (A51406)
2015 DODGE RAM...
Scaffolding (A52377)
UNUSED FUTURE HYD HEDGE TRIMMER (A51248)
UNUSED FUTURE HYD...
