ym 1500 transmision hydraulic oil
   / ym 1500 transmision hydraulic oil #1
thedart
australia
ym1500
hi
new in the forum. does anybody know what type of oil and how much
i shuold put back in my yanmar 1500,after losing it all because of some cut
in the pipe
no FEL on my tractor
thankes
   / ym 1500 transmision hydraulic oil #2
use a utf type oil.. walmart.. farm stores.. napa.. etc.
use yer dipstick as a level indicator..
thankes
maybe you know the viscousity grade?
   / ym 1500 transmision hydraulic oil #4
Don't know how much. The fluid should meet John Deere (JD) 303 specs. It should list this on the container. Post tjis a little father down ( in the yanmar part) some members have these (1500) yanmars. Nine is a 3110, but the fluid is the same
   / ym 1500 transmision hydraulic oil #5
thankes
UTF.. you don't have much choices on grade, unless you buy a premium oil listed for cold weather.
just about any utf out there made in tha last 2 decades will be suitable for that 70's era yanny tranny
   / ym 1500 transmision hydraulic oil #6
Go by the spec "jd 303" but its any UTF for trans and hydro common sump fluid like these guys said. I know a ym2000 is 4 gallons so a 1500 is prolly that or a shade under. I would buy a 5 gallon bucket and put in 3 and check it then add a half gallon or a gallon depending upon the level, im thinking 3.5 gallons maybe.
   / ym 1500 transmision hydraulic oil #7
i doubt you will be finding any whale oil anytime soon.. :)
hi there everyone
thank for reply
i cant find anything here in oz with the spec of "jd 303"
what i can find is utf oil name "hi gard" utf oil from jd dealer
is that would work?
   / ym 1500 transmision hydraulic oil #9
That should be fine. The Yanmars are simple, durable machines. Anything designed for use in hydraulic pumps and gear transmissions will do everything required. John Deere Hy-Gard will be great, as well as anything recommended by another major manufacturer like Kubota, Allis-Vhalmers, International Harvester, etc.
   / ym 1500 transmision hydraulic oil #10
if it meets higaurd specs it exceeds 303 specs. just not whale oil.. :)
hi there everyone
thank for reply
is that would work?
2017 John Deere 9620R Scraper Special Tractor (A53342)
2017 John Deere...
2014 RAM 5500 Bucket Truck - 4X4 - Cummins Diesel - Automatic Transmission -Versalift SST40 Boom (A53472)
2014 RAM 5500...
2018 Ford F150 Eco Boost Truck (A52384)
2018 Ford F150 Eco...
Paint Dryer, Briggs 5.5 (A52384)
Paint Dryer...
New Holland Boomer 55 Tractor (A52384)
New Holland Boomer...
2018 WACKER NEUSON RTSC3 ROLLER (A53426)
2018 WACKER NEUSON...
