ym 1500 pto
/ ym 1500 pto #1
smcbride
lexington,oklahoma
ym 1500
Hello guys, I just aquired a gray market ym 1500, and the pto only stays engaged when the clutch pedal is
depressed is this normal or can you engage it and it stay on with clutch pedel is disengaged?
Any help with this matter will be helpful. thanks.
/ ym 1500 pto #2
Live PTO=working when the clutch is engaged regardless of the gearing
Non-live PTO=working when the clutch is engaged and the tractor is in gear
Yours is probably a live PTO
/ ym 1500 pto #3
a yanmar is a japaneese tractor not chinese. ( you are in a chineese forum )
als.. the pto definitions above are not completey correct.
independent pto is generally independent of a foot clutch.
live pto generally is a 2 stage clutch and there is a pedal height that you can get to to clutch the drivetrain but leave the pto running.. and then full down clutches both.
non live pto is standard single stage. clutch pressed kills pto and drivetrain.
a 1500 should be non live pto.
are you saying the pto will only spin when you have a foot on the clutch?
/ ym 1500 pto #5
you normally have to depress the clutch, shift the pto IN, then let off the clutch.. and then it will spin.
if the pto spins ONLY when the clutch is pressed. you have some issues..
/ ym 1500 pto #7
let us know what you find.
2021 Kubota B2601 (A60462)
2021 Kubota B2601...
2016 MACK CXU613 (A60736)
2016 MACK CXU613...
JLG 20MVL MANLIFT (A58214)
JLG 20MVL MANLIFT...
SDlanch 20'x20' High End Carport (A60463)
SDlanch 20'x20'...
KBH Tender Trailer (A61307)
KBH Tender Trailer...
JOHN DEERE 850K WT CRAWLER DOZER (A62129)
JOHN DEERE 850K WT...
