YM 1110D Front End Seal Repair
   / YM 1110D Front End Seal Repair #1
OhioBruce
Yanmar 1110D
Hello All,
I recently picked up a 1110d and I'm trying to get it in shape to work. The front end leaked so I took it apart to install new seals. The housings were grooved so I installed Redi-Sleeves. I used Loctite 660 retaining compound to fill the grooves and hold the sleeve in place. I removed the flange and tapped it on until it bottomed out. After the Loctite hardened I used a dremel, file, and sandpaper to trim the end of the flange flush with the housing.
For the seals I used some 140 x 115 x 13mm seals I found at oringsandmore.com for $12.95. I used the ones with a dust seal above the sealing lip.
The Redi-Sleeves are National repair sleeve #99452 The sleeves are a little pricey, but my front end doesn't leak and I feel better about it than having filled it with JBWeld.
Hopefully this helps someone.
Bruce
Before:
After:
   / YM 1110D Front End Seal Repair #2
Welcome to the forum. :welcome: Looks like a job well done. :thumbsup:
   / YM 1110D Front End Seal Repair #3
Welcome to the forum! And welcome to Yanmar ownership.
You appear to be someone who looks at a problem and thinks outside the box for repairs! Looks like a great repair job that should give years and years and years of service.
Thanks for the compliments, guys.
2385 (A58376)
2385 (A58376)
Test Button (A55272)
DEUTZ MARATHON 60KW GENERATOR (A55745)
DEUTZ MARATHON...
John Deere Gator (A53317)
John Deere Gator...
2820 (A58376)
2820 (A58376)
2009 Chevrolet C8500 Dump Truck, VIN # 1GBT8C4B59F409922 (A57453)
2009 Chevrolet...
