Yikes!! What would you do to save the tractor from getting smashed?!
   / Yikes!! What would you do to save the tractor from getting smashed?! #111
I fill my tires to the right pressure in the fall because it seems cold temperature makes the pressure lower. My tractors are filled with fluid and it doesn't take a big imagination what kind of mess you will have if it runs low on air and you run the bead off the rim. The weight of the roof did not make your tires get low. I think it is just a gradual air loss, unless you see a puddle. Fil the up to the prescribed pressure while the valve stem is at the top.
   / Yikes!! What would you do to save the tractor from getting smashed?! #112
People are why I don't!! :)
And the heat. Plus Hurricanes, alligators, scorpions, copperheads, cottonmouths, diamondbacks and other various poisonous snakes,
   / Yikes!! What would you do to save the tractor from getting smashed?! #113
Yeah, those too..... :)
   / Yikes!! What would you do to save the tractor from getting smashed?! #114
Glad to hear you got your tractor safe.
Yep. Just had to adjust ALL my tractor, trailer, and vehicle tire pressures due to colder temps and I'm in FL.
   / Yikes!! What would you do to save the tractor from getting smashed?! #117
I saw that, sad.
   / Yikes!! What would you do to save the tractor from getting smashed?! #118
Funny how a place you've never heard of shows up in a couple of unrelated website stories just a couple of days apart.
   / Yikes!! What would you do to save the tractor from getting smashed?! #119
   / Yikes!! What would you do to save the tractor from getting smashed?! #120
I haven't read the whole thread, for all I know you may have already "solved" this.
My 2/5 of a nickle;
LEAVE IT ALONE !
It is the insurance company's problem and ANYTHING you do that worsens the situation will be YOUR FAULT
and (likely) not covered.
Even if you improve things and the professionals come along and turn it bad they could blame you.
Oh yeah, not to mention that the whole damned thing could come down ON YOU !
No tractor is worth getting hurt for, it is a tractor, that is all it is.
UNUSED PABREAK AR650 HYD AUGER (A57193)
UNUSED PABREAK...
Honda EM3500S Portable Gasoline Generator (A55851)
Honda EM3500S...
1987 Landall 48ft 35 Ton Hydraulic Slide Axle T/A Drop Deck Trailer (A55852)
1987 Landall 48ft...
Electric Mobility Scooter (A54815)
Electric Mobility...
2019 Autocar ACX Xpeditor T/A New Way 31ASL 31yd Automated Side Loader Garbage Truck (A55852)
2019 Autocar ACX...
BUNDLE OF 4" - 6" X 12' BUILDING PURLIN (A54757)
BUNDLE OF 4" - 6"...
