YIKES! My 1500D Alternator Shaft Is Messed Up
   / YIKES! My 1500D Alternator Shaft Is Messed Up #1
old_car_eddie
Prattville, Alabama
Yanmar 1500D
I own a Yanmar 1500D and recently had an alternator-related problem. Maybe someone has a part they can spare or at least some ideas for repair. Here's what happened: The shaft that runs through the alternator became gouged out when the fan-belt pulley loosened up. This shaft is the one that has threads on one end and the flange for the four fan-mounting bolts on the opposite end. Apparently the nut that goes on the threaded end loosened and allowed the bearings and the fan pulley to wobble, thus causing the pulley to cut a deep groove. The hole in the center of the fan pulley is so wallowed out that it is now egg shaped. I need the pulley as well because of the wallowed-out center. Does anyone have the shaft and/or pulley? How about repair ideas if the shaft or pulley can't be found? Thanks to all who read, and especially to those with help or advice. -- Ed Rouze (Prattville, Alabama)
   / YIKES! My 1500D Alternator Shaft Is Messed Up #3
I should have a good used alternator.
Danny
2021 International HV507 4x4 12ft Single Axle Dump Truck (A51692)
2021 International...
2015 Chevrolet Silverado 1500 4x4 Crew Cab Pickup Truck (A53422)
2015 Chevrolet...
Toro Multi Pro 5800 (A53424)
Toro Multi Pro...
ASCO Transfer Switch (A52377)
ASCO Transfer...
UNUSED Tool Set (A53117)
UNUSED Tool Set...
