YFL-155 Loader Specs
/ YFL-155 Loader Specs #11
I see the problem now. The manual that I was looking at was the YFL-155TH. It has (uses tractor pump) under it. That must be the difference between the "TH" and the regular YFL-155. Sorry about that.
Aaron
Parts@HoyeTractor.com
(940)592-0181
/ YFL-155 Loader Specs #12
I'm going to try 46 wt hydraulic oil in mine next time I get a chance. It's very possible that's what the previous owner had in it. GT14, where is the strainer located?
Also, have you every tried removing the pump? I tried once, but was surprised to find the pump hits the inside of the bumper before the splined shaft disengages. This makes it all the more challenging to remove the loader if I want to use if for a season of mowing only.
The strainer is located at the bottom of the loader arm that contains the fluid. Take off the low pressure line that feed the pump and unscrew the big fitting attached to the fitting is the strainer clean put back in and refill with fluid.
2017 Bobcat T770 Compact Track Loader (A61307)
2017 Bobcat T770...
2004 John Deere 4720 (A60462)
2004 John Deere...
2014 BRENNER TANK CRUDE TRAILER (A60736)
2014 BRENNER TANK...
HYDRAULIC AUGER FOR MINI EXCAVATOR (A58214)
HYDRAULIC AUGER...
Oxy-acetylene Torch and Regulator Rig (A61307)
Oxy-acetylene...
Volvo EC220EL (A60462)
