Planters Yetter 71 vs. JD Planter
   / Yetter 71 vs. JD Planter #11
The Yetters are $1,500, but considering how much the used JDs sell for, resale value, cost of other 3 pt gear, and how useful and well built these are, It's not too too bad.
It's great to find some folks knowledgeable about these. A couple of questions...
I'm trying to use with long slender snap beans and I'm using the B8-24. Does the bean have to fit in the plate cell (laying down horiz and parallel to the cell) or if they're too long for the cell, can they fall thru vertical (perpendicular to the cell) ok?
Do the same number of seeds pass thru regardless of speed?
Even with a 20 gear in the back and 14 in the front, I'm not getting enough seeds. Can I use a larger in back and smaller in front, or is there some point where it wont feed correctly? ... I see a warning about max MPH in the yetter manual.
I haven't used a JD/Yetter, but I've used a few plate planters.
You can mix the gears up any way you want to get the seed drop to where you need it.
Different speeds of driving will affect your seed population. It would be rare to accept going over 5 mph, and if you have a fast plate speed, you might need to keep below 3 mph. Typically getting over 4.5 mph gives you poorer seed placement.
With unusual seed dimentions, you just have to test it & see. I'm not quite visualizing your snap bean issue, but however they fit - plant on the driveway in the packed gravel, mark off a couple feet, and count the seeds. Look at how evenly they were placed. The seed will be on top of the packed gravel, easy to count. Look if any odd shaped seeds got damaged.
--->Paul
   / Yetter 71 vs. JD Planter #12
In my Deere 71 planter manual it lists "Plates for Edible Beans"
20-cell H1315B
24-cell H1301B
30-cell H2480B
I don't see those listed on Lincoln AG or Ebay though. Another option is to buy the blank plates and cut your own slots.
   / Yetter 71 vs. JD Planter #13
Lincoln Ag is very helpful and fast service. Just drop some sample seeds in an envelope and mail it to them with name and address and phone number and a note asking them to size a plate for you and they'll call you back and tell you what you need. I did that and was glad I did. It really saves time and seed. bjr
   / Yetter 71 vs. JD Planter #14
What do u have for sale in a two row unit in very good condition?
   / Yetter 71 vs. JD Planter #15
Has anyone seen a Yetter 71 up close that can comment on the quality and durability vs. the old JD Flex 71? Is everything just as heavy and well built (except for the obviously plastic hopper)? Is the build, parts, etc. just about exactly the same?
Thanks.
Just saw this old post. The ONLY difference is color of paint. And if you scratch the black on some part of the unit you will see green underneath.
2011 26PS PROWLER 5TH WHEEL RV (A52472)
2011 26PS PROWLER...
Landoll Lowboy Trailer (A55315)
Landoll Lowboy...
4 Unused Montreal ST205/75R15 Trailer Tires (A53421)
4 Unused Montreal...
City of Lakeland (A51691)
City of Lakeland...
2016 Ford F-550 Enclosed Service Truck (A55852)
2016 Ford F-550...
2013 Chevrolet Impala Sedan (A55853)
2013 Chevrolet...
