Buying Advice Yet another new guy looking for a compact, subcompact tractor...he thinks.
   / Yet another new guy looking for a compact, subcompact tractor...he thinks. #41
Steve1300, I think you already have your answer about making hydraulic connections, but in case not, just do this: with the tractor turned off, cycle thru the control valve(s) to relieve any pressure, and then make your connections. If your loader is off, sitting in the sun, then there may be some pressure built up there... but not so much you still can't pop the connectors together.
Also, if you're removing an attachment, such as a loader, and park it with weight bearing on one of the hydraulic cylinders, it will keep pressure in the hydraulic lines and make it hard to reconnect. For example, leaving the loader bucket slightly curled and not settled flat on the ground.
2023 BOBCAT T770 SKID STEER (A52709)
2023 BOBCAT T770...
golf cart electric (A55787)
golf cart electric...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A56858)
2019 Ford F-150...
2003 Ford Pressure Digger Truck (A55973)
2003 Ford Pressure...
2018 SkyJack SJ1056TH 10,000LB 4x4 Rough Terrain Telehandler (A55973)
2018 SkyJack...
Michelin CARGOXBIB High Floatation Tires (SET OF 6) (A55315)
Michelin CARGOXBIB...
