Yet another brush hog width question
/ Yet another brush hog width question #1
jimmysisson
W.Mass
1993 NH 2120 (the best), 1974 MF 135 (sold, but solid), 1947 Farmall A (bought, sold, bought back, sold again), 1956 MH50 lbt (sold, in 1980, darn it)
I have a 5' brush hog, and the sides come right about to the middle of the rears on my 2120. If I went to a 6', they'd reach just about the outside edge. Since the grass/brush gets crushed down by the tires, would a wider cutter actually cut more? When you're done mowing, the mowed grass and the crushed grass are about the same height, and grow back pretty evenly.
I'm sure I have power enough. At PTO rpm there's hardly any load on the engine, just a little mowing june grass.
This is what I think about mowing a 10 acre field: how can I do this quicker!
Jim
/ Yet another brush hog width question #2
jimmysisson,i would always get a hog that comes to the outer most part of the rear tire if your tractor will handle it hp wise.if you don't then you are just wasting time by going with too narrow of a cutter.
whitearrow->>>------------->
/ Yet another brush hog width question #3
Go 6 foot. The blades will produce an upward suction that will cut the knocked down grass, unless it's wet.
/ Yet another brush hog width question #4
Jim, you do realize that a 5 foot will have a wider than 5 foot deck and cut a 5 foot path. If your in the center of your tires now you may want a 6 foot if you have the HP for it? And the upward suction is in the blade shape not the width, they are called uplift blades or high lift
Jim
/ Yet another brush hog width question #5
Jim
The 2120 has plenty of power for a 6 footer, and maybe even a 7 footer. I went from a 5' cutter up to 6', and the time savings took me by surprise. It saves me around 2 hours of mowing time.
If you're only mowing grass and light weeds on smooth ground, consider a finishing mower. They are a bit easier to pull than a brush hog, so you can pull a 9 footer with no problem. They mow lower, and that eventually kills off weeds and tall-growing grasses. The result is that you spend a little less mowing, your field looks great, and it's much easier on your equipment.
/ Yet another brush hog width question #7
I'd get a 15 foot Batwing; nothing less.
Just kidding. . .
I agree with above that the mower should come to the outer width of the rear tires. I want to get a 7 footer (84") so that the mower is even with my rears.
/ Yet another brush hog width question #8
I have a 6' that extends 3"-4" past my tires. I have a simple 2 wire elec fence separating off about 2 acres where my shop is to keep the cattle away. By going slow and weaving slightly around the T posts, I can actually mow just under that fence. Then when I mow the other side, I do the same and it keeps my fence row from growing up. Of course, I do have a few T posts leaning at a slight angle where I didn't weave quite enough. :rolleyes:
/ Yet another brush hog width question #9
BB TX:
If those Olympic skiers do it why can't you :p. Jay
No one's addressed the crushing question (except MrJimi), which was really what I was posting about. If the grass/brush under the tires is crushed under the tires, and it doesn't spring back up (or pulled up by uplift blades) to get cut by the hog, what benefit is there to having the hog out to the edges of the tires, as opposed to the middle? I see the benefit of "mowing" right up to fences, etc., but for that to really work I'd need to get a 7' mower, which is probably right at the limit for my tractor, pricy new and rare used.
When you look at a hogged field, the tire tracks appear as matted down stripes, with mowed grass/brush between, and all roughly the same height. As the field grows back up, competition among the plants keeps it more or less at the same height, so a couple of weeks later it's pretty even. So, aside from the fenceline benefit, do I gain from the extra few inches which will be right behind the tires.
Not trying to be cranky, just curious.
Jim
/ Yet another brush hog width question #11
I guess it all depends on how you wanted the mowed pasture to look. You can use the more narrow mower and squish down the grass with the tires at the edge or you could mow that same width. Either way, the grass is going to be "level". But my personal opinion would be to get a wider mower, go slower so that the grass has a chance to spring back, and cut it all the same length instead of just mashing it down. But I'm the kinda guy who is picky about things like that and wouldn't feel right unless it was all mowed the same height. A wider mower would then give you a cleaner cut and also allow for the mowing and triming obstacles as already mentioned. But, as stated above, I'd like my pasture to look like a golf course sometimes. It may be perfectly reasonable for you to decrease the grass height, by whatever means, and save the money by using a cheaper more narrow mower. A lot of it has to do with personal preferences.
/ Yet another brush hog width question #12
BushHog has a light duty 84" cutter that is offset. It will track even with the outside of the left rear and extend about 1 1/2 foot past the right rear tire. This cutter has 2 rear wheels and it should work on a 40HP tractor.
/ Yet another brush hog width question #13
I always prefer a mower that covers the rears on the tractor.. same with a box blade.
Soundguy
Jim
2015 Ford F-250 Pickup Truck (A61567)
2015 Ford F-250...
Mini Universal Forks (A65640)
Mini Universal...
2016 WESTERN STAR 4700SF DUMP TRUCK (A59914)
2016 WESTERN STAR...
John Deere 6200 Tractor (A64047)
John Deere 6200...
Caterpillar 303.5E CR (A64126)
Caterpillar 303.5E...
4ft Mini Skid Quick Attach Rotary Cutter (A63689)
4ft Mini Skid...
