yellowed headlight lenses
   / yellowed headlight lenses #1
deerefan
louisiana
1952 8N, 2005 JD 5103
My 97 F150 headlight lenses have "yellowed" over time, making the lights very dim at night. Has anyone else encountered this and is there a resolution to the problem other than buying a whole new assembly?
   / yellowed headlight lenses #2
In auto industry there's a few products, here's one BRITE LITES and a phone # 800-792-7437.. good luck
   / yellowed headlight lenses #3
I know there are some kits out there that you can use that are supposed to help. I belief it is basically a plastic rubbing/buffing compound. You buff off the outer layer of discolored plastic leaving you clear plastic underneath. I know there are some $19.95 kits, but there are some good kits that I would try instead. I have seen them used on Motorweek on tv, in the Goss's garage segment. I personally have never used them, but I know that the Ford pickups of that era have this problem often.
Good luck, Dave
Here is an example:
Acrylic Restoration
   / yellowed headlight lenses #4
Maguire's "cleaner wax" not only does a nice job on the car/truck's paint, but will clean the cloudy lens in a few minutes with some elbow grease. Maguire also make a plastic polish that would clean them to "like-new" condition, but it can be rather difficult to find (I've cleaned 30 year old faded tail light lenses & plastic dash lenses with the plastic polish & they came out looking like new, plus did a Dodge mini van headlights with the cleaner wax last year & in only a minute, literally one minute, it made a considerable improvement).
   / yellowed headlight lenses #5
Mother's Aluminum Wheel Polish. Recommend by Chrysler for this problem. Takes just a few minutes. It takes the haze off.
I'm going to try these...its got to be cheaper than a new one. Thanks a ton...its gotten really hard to see at night.
   / yellowed headlight lenses #7
Good luck... we have 2 older ford products with this problem.. our dealer ordered some 'magig goop' kit to do what has been said.. didn't effect them... hope you have better luck..
Soundguy
   / yellowed headlight lenses #8
A local body shop is restoring them for $25.00 per lens- his before and after are pretty impressive.
   / yellowed headlight lenses #9
Sam Memmolo on "2 Guys Garage" used toothpaste to buff the head lights clear. I haven't tried it at home yet on my '98 Explorer but it worked on TV! :D
Regards,
Duber
   / yellowed headlight lenses #10
Regards,
Duber
YES!
Toothpaste is great for refinishing all types of plastics!
-Mike Z.
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A53421)
2025 Kivel 48in...
2012 JOHN DEERE 329D SKID STEER (A52705)
2012 JOHN DEERE...
2006 Imperial 14Ft Flatbed T/A Equipment Trailer (A50324)
2006 Imperial 14Ft...
2014 Ford F-150 Pickup Truck, VIN # 1FTFX1ET4EKG11918 (A54865)
2014 Ford F-150...
2015 John Deere 7700A Mower (A52377)
2015 John Deere...
