Yee Hawww
/ Yee Hawww #21
YOU WONT BURN MORE THAN 8 TO 10 GALLONS AN HOUR. DO YOU PLAN ON RUNNUING TWO SHIFTS
/ Yee Hawww #22
you wont burn more than 8 to 10 gallons a hour. do you plan on running two shifts
/ Yee Hawww
No just one piece of equipment with me right now. 8-10 GPh, I wish. My 140 horsepower Fecon 140-148 burn 7-9 GPH. This is 305 horsepower. They did not put a 126 gallon fuel tank on it to run two days. The job that I am on looks like a brush job but it has a lot of tops and blowdown that I am having to process into the soil.
/ Yee Hawww #25
Very nice machine indeed, when you hit some slack time let me know and I will give my address so you can come demonstrate it on my place..
/ Yee Hawww #26
im running similar equitment and get 8-12 gph you must be really hammering down
/ Yee Hawww
Not to change the subject but what are you running.
Willie,
Keep that big ugly brute away from my big ugly princess. All we need is a couple more 148s running around that we have to find work for!
/ Yee Hawww #30
bh 350. are you sure your burning gallons.it only 190 .pretty expensive
/ Yee Hawww #32
190 gallon tank . i run about 75 to 100 a day at 2000 rpm
/ Yee Hawww
You must be mowing blackberries. I see no way how I could manage 425 horsepower to only burn 10 gph. The stuff I find myself in all the time I can burn 75 gallon a per day in the 140 and 148! That requires a 10 hour day but that is just a good start for me most days.
Just a little not to all of my illegal dumping friends. Your old tires do not belong out in the woods. You are a donkey, I hate you and you owe me $400 for the hour I wasted digging your tire out of my head today!
/ Yee Hawww #34
i live in tn .come on down here and see what we are cutting. you dont have to boarhog it with 400 hp
/ Yee Hawww
I live in Tennessee. I am cutting blowdown and clearcut cleanup in MS right now and I am burning 100 gallons in 8 hours.
/ Yee Hawww #36
thats more like it .you are running it @ 100 percent .wideopen.im running at 90 percent and saving a little fuel.
/ Yee Hawww #37
CB where are you running??? I wanna come see that thing in action!!!
I'm in Hattiesburg!
/ Yee Hawww
Hattiesburg just nort at the 73.
615-394-0457
/ Yee Hawww #39
I run mine at 100% all the time, I charge accordingly and I don't want to be accused of not providing what I'm selling. If the machine burns that little at 2000 I may just run it around there and charge accordingly I guess. :thumbsup:
/ Yee Hawww
My point was that I am cutting easy stuff! There is nothing really hard that drags the machine down. 99 percent of what I am cutting is dead or down. I do not recommend running the machine at less than full rpm. By doing this your pumps are spinning slower and not giving your hydraulic components they need. Since my machine is cooled by a hydraulic fan motor I will always run full rpm. The engine will only make the amount of horsepower that it needs. If you look at your pressure gauge the pressure is very low while the head is spinning free, once you put a load on it it goes up. SMe with the engine, just running with no load does not use that much more fuel than slowing the engine down. Our engines are made to run at a certain speed, there where a lot of guys a whole lot smarter than me that designed those babies.
2021 TORO 07411EX CART (A66091)
2021 TORO 07411EX...
2014 MACK ELITE LEU613 GARBAGE TRUCK (A63276)
2014 MACK ELITE...
520/85R46 MICHELIN TIRE (A64278)
520/85R46 MICHELIN...
1995 Ford LT9000 Tri-Axle Dump Truck (A64556)
1995 Ford LT9000...
2001 THOMAS-INTERNATIONAL 3800 SCHOOL BUS (A64280)
2001...
2023 KUBOTA KX040-4 EXCAVATOR (A65053)
2023 KUBOTA...
