Yearly Service
   / Yearly Service #1
cmyoung2
Platinum Member
North west NC mountains
BCS 850, Kubota BX2230 w/FEL, mid mount mower, 41" tiller Kubota L3600 w/4-1FEL, Farmi winch
I try to service all my equipment in the spring, whether it need it or not. If it needs it during the year I do it, but everything gets it in the spring. Oil change, all filter change, fix the minor stuff, make sure everything is clean and greased. I don't put that many hours on any one thing, usually 50-100 on each tractor. So this week was that time. Ordered filters from Messeck's so they would be right. Started on the BX, engine oil, no problem, air, no problem, when I pulled the Hydraulic filter the fluid was milky (been too long since the last change) so trip to town for more fluid.And the Hydraulic oil is a pain to refill. It has 2 fuel filters, not hard to change, a little challenge to get it primed. Took somewhat longer than I was expecting--of course--. The L3600 was fairly easy, engine oil filter easy, easy to drain, PITA to refill engine oil. Hydraulic filter easy, fuel filter easy except the fuel shutoff for the bowl didn't work, probably only lost a quart or so down my sleeve. Then the air filter was not the correct one, seems there are more than one listed for the L3600GST, so trip to NAPA, but was able to get a new fan belt, so not a total pain. So both tractors were washed, serviced, and running good, except the L was idling too fast. After looking-with a flashlight in the bright sun- I found a half eaten walnut left from a squirrel. The joys of equipment. Now for all the small engines. The way I found to add oil or hydraulic fluid to the hard to access fill ports is something similar to this.
HORUSDY Multi-Use Siphon Fuel Transfer Pump Kit for Gas Oil and Liquids​
Takes a lot of pumping, but it is fairly cheap and it works for the hard to pour in ports. Maybe 2-4 oz/stroke.
   / Yearly Service #2
I bought a pump to replace the hyd fluids. I went cheap as I use it once a year or two. SOOOO slow. I turn it on and walk away like 10-15 minutes and half the 5 gallon bucket is in it. Gonna look at the one above, need something bettern what I got.
2016 JOHN DEERE 135G (A58214)
2016 JOHN DEERE...
PT 1000 Gallon Supply Tank (A57149)
PT 1000 Gallon...
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
2013 John Deere 824K Wheel Loader (A56438)
2013 John Deere...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2015 MACK CHU613 DAY CAB ROAD TRACTOR (A58375)
2015 MACK CHU613...
