TC45DA, TC40DA, Farmall Super A, New Idea spreader, Dolmar and Echo saws, Yanmar MIniEx, Ford 3550 backhoe, lots of junk
sometimes with the older mowers and tractors, the easiest thing to do is to find out the age of the engine. Most have the same age engine and tractor, unless the engine has been replaced. Local small engine repair shop should be able to tell you the engine age based on the model/type/serial number.
/ Year of Manfacture on Montgomery Wards Lawn Tractor
Kubota '2003' L3000DT 8/4 std, engine/pto hp 32.1/27.5, hyd 6.9 gal/min
There should be a metal tag on the dash tower on the right side under the gas tank. I found an unbelievable group of guys over at yahoo.com/group/GilsonCollectors
You will find everything you could ever need in their files section
