Year my Mahindra was made?
   / Year my Mahindra was made? #11
No, I just did the search back in the archives and found what I was looking for - The letter in the serial number designates what year it was made, at least on the 4110's. My serial number is 411 U03 0043. The U designates 2001 and if I remember correctly the 03 designates March. The 0043 is the actual production number. A "V" would be 2002, "W" would be 2003 and so on. I don't know what they did after "Z" or whether the other Mahindra models follow this method. This is similar to automotive VIN numbering so I would guess they might start back at "A" or perhaps go to a number designation for that particular digit in the serial number.
Stopping by in 2024 here to confirm what you said. My tractor has a "K" for the year designator and was made in 2016. If you start at W=2003 and wrap back to "A" after "Z", then sure enough, "K" = 2016. So obviously Mahindra is still using this convention and it is the same across models.
   / Year my Mahindra was made? #12
That works on TYM-built Mahindra tractors. Mitsu built use a different method, then the Mahindra built ones also have their system.
   / Year my Mahindra was made? #13
You said that back in 2012.
Thanks for this.
I have a 3510 Bought it used in about 2012. The only indications I had on age was from the wheels. which are stamped with a month and year.
The SN on mine is 3510 v12 xxxx, so December 2002.
2015 Ford F-150 Ext. Cab Pickup Truck (A53422)
2015 Ford F-150...
(2) 48" HANG ON FORKS (A54757)
(2) 48" HANG ON...
A40G DUMP BED (A55745)
Deere 333G (A53317)
Deere 333G (A53317)
2007 Heil Heavy Duty Aluminum Tank Trailer (A55314)
2007 Heil Heavy...
403 (A52706)
403 (A52706)
