Ye Haw!! Finialy got the 2120 back together.
   / Ye Haw!! Finialy got the 2120 back together. #1
shaley
Platinum Member
Tidewater VA.
Ford '92 2120
Boy, this took a long time to finish but it was worth it. Painted sheet metal and Replated most of the fasteners as you can see in photo of 3PH.
Three point photo
Tractor Pic
On to the FEL !!
   / Ye Haw!! Finialy got the 2120 back together. #2
Steve, nice job. I see your 2120 suffers from the same weak lower links as ours. They really should have been made from thicker steel.
   / Ye Haw!! Finialy got the 2120 back together. #3
Why did you have it torn down?
It needed a paint job and a front wheel bearing. It looked like based on the failure pattern the bearing had trash in it from the factory and the cage decentergrated which caused the ball spacing to vary causing the front seal to leak. It all took 10 years to fail, I'm impressed based on the number of 17cu ft loads the FEL has handled. The paint failed from the last owner using it to plow snow and spread salt once without washing it off. It developed small rust spots on hydraulic lines and other critical components that if not cleaned and repainted would cause major stuff later. So I painted the sheetmetal and re plated the fasteners and hardware.
   / Ye Haw!! Finialy got the 2120 back together. #5
You did a nice job! Congratulations on getting it all back together. RaT...
   / Ye Haw!! Finialy got the 2120 back together. #6
</font><font color="blue" class="small">( So I painted the sheetmetal and re plated the fasteners and hardware. )</font>
So, are three of the left-front lugs still in the plating shop? /forums/images/graemlins/blush.gif /forums/images/graemlins/smile.gif
That looks like something I'd do, rushing to get a picture. /forums/images/graemlins/wink.gif
Your 2120 looks like a new one. Very nice! /forums/images/graemlins/cool.gif
How many rear remotes can you put on a 2120?
I had bought all new lug bolts but hadn't plated them yet. Just painted the rims this weekend, new front tires tomorrow.
You can put 2 remotes on the rear. I run a log splitter on mine. The BH has it's own hyd.
UNUSED KIVEL 3500# PALLET FORKS (A51248)
UNUSED KIVEL 3500#...
2025 INDUSTRIAS AMERICA 227T 7' X 22' HYD TILT TRL (A51247)
2025 INDUSTRIAS...
2007 CATERPILLAR D5GXL CRAWLER DOZER (A51406)
2007 CATERPILLAR...
2021 Triple Crown U6X14T 14ft T/A Flatbed Trailer (A51694)
2021 Triple Crown...
2022 Big Tex 22GN-35BK+5MR 40ft T/A Gooseneck Equipment Trailer (A51691)
2022 Big Tex...
