Yard trailers - what have you got?
   / Yard trailers - what have you got? #21
Plumbstraight, I think you've posted that before. I still think it's one of the coolest designs for an ATV trailer/log arch I've ever seen.
   / Yard trailers - what have you got? #24
I use a Lowes camo trailer 5x8. Mostly for brush. With its ramp I can load up a mower if I need to. The truck can take it on the road -but mostly just use the tractor.
   / Yard trailers - what have you got? #25
Here’s mine, it’s about 4.5’ x 9’ big enough to haul standard 4x8 sheets of plywood. I built it myself using northern tool running gear and pressure treated deck. Sides are removable for bulky objects.
It works well but the only down side, as others have mentioned, is that it’s impossible to back it like a single axle trailer. If I had to do it again I’d probably go with a single axle and move it with a ball hitch on the 3pt.
   / Yard trailers - what have you got? #26
Difficult yes,impossible no. Not that long ago,all farm trailers were like that. Many still are. I was around 10 when I finally mastered backing them.
   / Yard trailers - what have you got? #27
Hereç—´ mine, itç—´ about 4.5 x 9 big enough to haul standard 4x8 sheets of plywood. I built it myself using northern tool running gear and pressure treated deck. Sides are removable for bulky objects.
It works well but the only down side, as others have mentioned, is that it痴 impossible to back it like a single axle trailer. If I had to do it again I壇 probably go with a single axle and move it with a ball hitch on the 3pt.
Much easier to back a wagon with a front hitch :D:
   / Yard trailers - what have you got? #28
The other big upside to those is you can tow several of them at a time and they will all track one right behind then other.
   / Yard trailers - what have you got? #29
Single axle trailers not exactly tracking one right behind the other, but close enough to get around :D.
   / Yard trailers - what have you got? #30
I built the above one about 25 years ago. I use it to haul the ATV among other things but I also pull it around the yard with the ATV.
I built this one 5 to 10 years ago, it is only pulled by the ATV. I use the winch on the back of the ATV to dump it.
Generac XG8000E Generator (A55973)
Generac XG8000E...
EquipmentDealz (Shipping Terms and Instructions) (A59213)
EquipmentDealz...
2015 FREIGHTLINER CORONADO 122 SD (A58214)
2015 FREIGHTLINER...
2007 Volvo VNL Truck Tractor (A56435)
2007 Volvo VNL...
2013 FREIGHTLINER CASCADIA (A58214)
2013 FREIGHTLINER...
2018 Ford F-350 (A55973)
2018 Ford F-350...
