Yard machine log splitter 26ton changed engine from vertical to horizontal.
   / Yard machine log splitter 26ton changed engine from vertical to horizontal. #1
jkk04
PLYMOUTH CA
John Deere 410 backhoe, MF 30 industrial tractor, IH TD-14 dozer, New Holland TZ24DA
It was a fun projection and I am glad the splitter works well.
If you have a problem with a vertical engine, better to consider changing to a horizontal engine.
It is much easier to maintain in future.
Hope this video helps someone who needs to do so...
John
   / Yard machine log splitter 26ton changed engine from vertical to horizontal. #2
Very good.....
I bought a 30 year old DURR splitter with a puked B&S horizontal engine that needed replacing. New B&S was like $375.... New Predator from HF was $139.... Can replace Predator in future if necessary and still be ahead for cost of B&S.... Only issue was shaft on Predator was about 1/2 inch longer than B&S so I had to space out pump mount about that 1/2 inch (1/2 nut and a washer between pump mount and engine block made a good spacer) ... Yes I could have cut engine shaft but that would have violated warranty (?).. The amazing thing was form factor of Predator was exactly same as B&S as for bolt thread type and mounting dimensions....
Very good.....
I had exactly the same problem on the new engine shaft.
That was the reason I purchased the new pump bracket from Ebay for $25 and installed.
It was perfect fit.
I think it would be much easier to replace it instead modify the shaft.
John
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
CATERPILLAR 21" PIN ON BUCKET (A52706)
CATERPILLAR 21"...
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2024 CATERPILLAR 305 CR EXCAVATOR (A52709)
2024 CATERPILLAR...
Vermeer 605 XL Round Baler (A59814)
Vermeer 605 XL...
2011 VOLVO VNL760 SLEEPER (A59904)
2011 VOLVO VNL760...
