Yanmar YM240D OVERHEATING
/ Yanmar YM240D OVERHEATING
Here are some pictures that may help.
/ Yanmar YM240D OVERHEATING #12
You can try to weld it .I use nickle rod for cast iron. If you'er having problems with it now . you have nothing to loose to try the weld route.
/ Yanmar YM240D OVERHEATING #13
Bugyman said:
Well i'm back, seems i've got way too many irons on the fire any-hoo first let me say that after reading my previous post i must have had a brain fart its running 240+ not 140. Ive been running it till it heats up then letting it cool down trying to get some nesesary work done (hopefully I havnt harmed it) now i've brought it home and torn into it expecting to find the water jacket pluged up (previous owner used that powdered metal "stop leak" when the J-B weld would start leaking) but only found rust and rust scale piled in the low areas. the head gasket looked good, but with all the over heating i'm going to take the head to be checked for warping. Im also takeing the radiator to be cleaned out. Now, anyone jot any ideas on how to thourly clean out the block? also howabout welding up the block, can it be done?
I believe I'm seeing totally blocked water passages. About all you can do, short of removing the engine, stripping and taking the block to a machine shop for cleaning and welding, is poke out the water passages with a wire, to hopefully get some water flow, put it back together, start running radiator flush, and hope for the best. You may have to live with the crack.
/ Yanmar YM240D OVERHEATING #14
You should weld it or replace the block. Do you know that antifreeze is very toxic to children, pets, and wild life? If you go around dripping antifreeze all over your land....well it is not good. I think a skilled welder could weld that up for you no problem. Where in Kansas do you live? Alot of these old boy farmers have alot of experience welding up blocks. Now is the time to do it. When you have the head off and it is dry. You should have your radiator boiled out. I think with all that rust in your block your radiator has got to be bad.....Welcome to the yanmar forum..
/ Yanmar YM240D OVERHEATING #15
Yes, depending on where in Ks you are, I could point you to someone who could weld it up, he's done some cast iron welding for me already and did a great job. Let us know where you are, OK?
I'm in Kansas City KS. near I-70 & I-435. If I could find someone who has made this repair before that would be great.
/ Yanmar YM240D OVERHEATING #17
u realy need to have that block vated before u have someone fix it.
sorry for the typo. acid vating it where u have the block dipped by a engine shop into acid it eats all the junk of out the block would clean it up like new and i think it will take the quick steel off as well for an easier weild. but if he is gonan keep the block its a sure fire way to get all the grime removed from his water path.
/ Yanmar YM240D OVERHEATING #18
Vated?
Bugyman, I'll send you a PM with a guys name - he's in Eudora, just about 10 miles south of you off K-10.
Obviously, the best thing to do would be to replace the block with a good one, but if none are available or too expensive, this might do the trick.
/ Yanmar YM240D OVERHEATING #19
If you had to remove, and strip or replace that engine, you would be better off to just "part it out" and buy something else.
2008 FORD F350 XL SUPER DUTY DUMP TRUCK (A62130)
2008 FORD F350 XL...
2015 Freightliner M2 106 AWD Altec DM478BTR Insulated Digger Derrick Truck (A60460)
2015 Freightliner...
2017 ADDCO ROAD SIGN DH1000-ALS (A60736)
2017 ADDCO ROAD...
2023 NEW HOLLAND WAGON TONGUE AND LOADING CHUTE FOR NEW HOLLAND SQUARE BALERS (A55315)
2023 NEW HOLLAND...
2014 International WorkStar 7300 4x4 Altec A55F 55ft. Material Handling Bucket Truck (A60460)
2014 International...
2014 FORD F-250 XL SUPER DUTY EXT CAB TRUCK (A59823)
2014 FORD F-250 XL...
