Yanmar YM2000A-A pictures
   / Yanmar YM2000A-A pictures #1
rbhoppe
Yanmar YM2000A-A
Hello all, now that I know what tractor I have thought I'd share some photos for reference. I know when I was trying to figure it out I couldn't find pictures that matched, so hope this helps someone. While looking at the pictures I noticed I have a check chain pin just about to fall out...I'll get that fixed next week :).
   / Yanmar YM2000A-A pictures #2
Looks as though the wiring to the dash and switches are different than mine. Esp. At the Radiator drain were you have a fusible panel? One switch looks different Under the Tac. I Don't have that or the Fuel bowl to the Thermal start. Which I never use. Nice Tractor! The TR20A-A only seen a few! I added Front weight ballast By adding old Anchor lead from a local lake I collected over the Yrs.. Helped a lot without any complaints. My FM would lift the front wheels almost off the ground if it was 3Pt. lifted. Small bump in my gravel and you could tell it.
I was looking at a parts manual just now for the YM240 and noticed that the engine serial number doesn't match the 2TR20A but does match the 2TR20A-X. Did they mix and match engines among models?
Thanks, I really have no idea if there were modifications before I got it, this was my first tractor I've ever owned, I am quite the newbe. I mean I only discovered the compression lever just a few months ago after having it for 2 years :). So any info/advice/criticism is appreciated.
   / Yanmar YM2000A-A pictures #5
Mines Org. With Typical repairs. Like your Starter has been rebuilt and has the same Gold coil. I have a 195/240 Operators manual If you want it! PM me or Personal message me and I can Email it to you. Files to big for TBN.
2009 FREIGHTLINER CASCADIA SLEEPER (A51222)
2009 FREIGHTLINER...
2014 CATERPILLAR CT660S SBA 6X4 DUMP TRUCK (A51406)
2014 CATERPILLAR...
New Holland TS6. 120 Tractor (A50322)
New Holland TS6...
2004 Kenworth T800 Day Cab T/A Truck Tractor (A49461)
2004 Kenworth T800...
2011 Ford Utility Econoline Van (A50515)
2011 Ford Utility...
2019-2024 Dodge Ram Front Bumper (A49461)
2019-2024 Dodge...
