Yanmar YM1700
/ Yanmar YM1700 #11
</font><font color="blue" class="small">( I am in Spokane, and have been looking for tractors for over 8 months)</font>
Bob, Take look at www.ernies.net in NW Oregon. Last spring I purchased a Yanmar F20D from Ernie. Great guy, real honest and up front, and he has a good supply of parts tractors. I don't have one complaint or regret. /forums/images/graemlins/smile.gif
There's another grey market importer in SW Washington, I won't mention by name, but the zero hour meters and bs about Yanmar IS a John Deere did not sit well with me.
Daniel
/ Yanmar YM1700 #14
Thanks Inspector...
I have been watching the EFC site for a while now, but have not found anything to meet my needs just yet. I'll keep trying!
Thanks again
/ Yanmar YM1700 #16
I purchased a 1700 about five years ago. I gave 3K for the tractor and tiller, the price included changing all fluids, replacing bad seals and a new seat. I sold the tractor the first quarter of this year and got my money back. I had excellent luck with the tractor, just needed a 4wd with FEL.
/ Yanmar YM1700 #17
NEED HELP. Can anyone provide me with the technical specifications (weight, length, 3 pt distances, PTO size) that is required for a bush hog that has to fit a YANMAR YM1700. Can an older bush hog fit one of these Grey Market tractors (in particular, the YANMAR YM1700)???
Thanks,
Dell
/ Yanmar YM1700 #18
I can't give you most of the info of fthe top of my head.. but I'm sure a dealer will pop in.
The PTO is a standarg 1 3/8 6 spline pto.
I used the shorter of the two cat 1 toplinks that TSC sold.
I changed out my lower lift arms for the generic 'ford' lift arms that TSC sells. They were longer, and let me use implements with a wider pin spacing. I still had to turn the pins in on some stuff, like a 30" scoop, and a box blade. Might still have to do that with a rotary mower, but if so.. it won't 'hurt' anything. Just get something that has pins you can reverse. ( That said, I used alot of stuff that that a tractor bigger than a 1700 might tote.. that 30" scoop, for instance.. it was quite a load, and I had to add a few hundred pounds of front weight to use it properly. A 4' mower will be easier to hook up than the 5' mower I used.
Look at pinning carefully. For instance.. it is easy to turn the pins 'in' on a kk mower.. but on some brands.. like a howse for instance.. it may not be so easy.
I'm gonna guess at 1800# weight for the ym1700.. lets see how close I am!
Soundguy
/ Yanmar YM1700 #19
Thanks. To be honest, I haven't even went and looked at the target cutter. I just wanted to get some information to see if the 1700 would even pick up the thing (save me a trip).
Dell
/ Yanmar YM1700 #20
The 3pt lift on my ym1700 is stronger than the lift on my ford 8n.. my 8n lifts 700-800 ponds befor ethe pump strains and the front end gets light.
The front of the yanmar 1700 gets light a bit over 500# on the lift.. however the lift itself can do much more. Front weights help. Before I had front weights.. my 1700 was a teeter totter when I had a full scoop of clay in the 30" scoop on the rear.. was kinda fun for a few seconds anyway!
Soundguy
Soundguy
2019 Deere 35G (A53317)
2019 Deere 35G...
2021 Bobcat E42 R2 Series (A60462)
2021 Bobcat E42 R2...
John Deere 4520 (A60462)
John Deere 4520...
2017 FORD TRANSIT 350 SERVICE VAN (A59823)
2017 FORD TRANSIT...
2022 Ford F-150 Pickup Truck, VIN # 1FTMF1CB1NKE47600 (A61165)
2022 Ford F-150...
John Deere 1025R (A53317)
John Deere 1025R...
