yanmar ym1500 oil flow rate?
   / yanmar ym1500 oil flow rate? #1
billymc
south west scotland
yanmar ym1500 also massey ferguson 35 son
hi guys do any of you know what the pump for hydraulics flow rate is ie gallons a minute on the ym 1500 to see what log splitter would be best. thanks
   / yanmar ym1500 oil flow rate? #2
Check on your hydraulic pump for the data plate. It will probably say 5cc/rev, meaning it displaces 5 cubic centimeters of fluid per revolution, which works out to about 2.6 GPM at 2000 RPM. I don't think this is anywhere near the volume needed to run a splitter at a reasonable speed with sufficient splitting power, but I've never used one.
no im pretty sure it wont but just wanted to know what you guys thought about it i think its either a bigger compact? or a pto drive splitter ?
   / yanmar ym1500 oil flow rate? #4
I wouldn't give up yet. My loader runs ok off what I think is that same pump. It's not real fast, but running from the tractor hydraulics is simpler and cheaper than adding a pto pump. I suggest research some more. There must be someone on here who has tried both.
   / yanmar ym1500 oil flow rate? #5
i have a 14 ton splitter, have had for more than 12 months but still have not plumbed it up so i cant tell you yet how well it works. :cool:
   / yanmar ym1500 oil flow rate? #6
i wanted one and think i posted on attachments the pic of one i found. one they said the price was to high for it, which i really wasent asking but it looked pretty normal sized for a splitter, and they said the same i have about 2.5gpm and it would take something like 30 to 45 seconds to cycle the thing at operating speed! and most folks high idle when using a splitter, which u cant do.
o ive seen some here they say they are for compact tractors but i dont know if they are newer compacts and have bigger pumps they dont say? they do sell one here with the pto pump combined buts its around £500+ more than a standard splitter. what size of compacts have quite a good size pump on them or are newer compacts the way to go for plumbed pipe work?
   / yanmar ym1500 oil flow rate? #8
i think there more designed for older tractors and or newer ones like kubota or jd that have loaders and larger pumps.
yes im not needing the splitter at the moment as i have the winter wood done so will just hang fire till i check into it a bit more will let you guys know how it goes thanks again
   / yanmar ym1500 oil flow rate? #10
I think pressure is going to be more important than volume in priority these tractor pumps are about 2200-2500 max psi. JJ can give you more info than me on specifics but I converted my 5hp 3000 psi 2 stage splitter to tractor hydraulics last year.
A pto pump will be the way to go imho and you will need a reservoir or use the one thats on the splitter now.
Granted it works and does what I intended but it is slow and the power is down quite a bit from the little gas engine that used to run it. hth
edit: Talking about other CUT that may run one cant help there but-fyi if this helps I believe my pump is around 7 or 8 gpm and is set @ 2250 psi (think thats right) and am using a 3.5" x 24" cyl which @ 3000 psi is rated @ about 20 tons. My setup now is no where near as powerful or fast as the 5hp 2 stage pump gas engine was. I put a 2 stage control valve on it for regen speed @ low psi and it helps to have the 2 speeds but is lacking on power, in fact I think I remember it only being about 14t or less? I had a thread about it awhile back if interested. Here it is http://www.tractorbynet.com/forums/hydraulics/221064-need-pto-log-splitter-guru.html
2018 JLG 4045R 40FT. Electric Scissor Lift (A51691)
2018 JLG 4045R...
2006 CATERPILLAR 312CL EXCAVATOR (A51406)
2006 CATERPILLAR...
2017 CATERPILLAR D6K2 LGP CRAWLER DOZER (A51246)
2017 CATERPILLAR...
2022 KMC 21-39-HD LOT IDENTIFIER 183 (A53084)
2022 KMC 21-39-HD...
2018 SkyJack SJ1056TH 4x4 Rough Terrain Telehandler (A52377)
2018 SkyJack...
(3) STEEL CARTS (A51248)
(3) STEEL CARTS...
