yanmar ym 1500 battery?
   / yanmar ym 1500 battery? #1
billymc
south west scotland
yanmar ym1500 also massey ferguson 35 son
ok guys i think the battery is on the way out it just seems to go back to around 75 percent charge and in the cooler weather its not enough to start it? so what do you guys fit ie like cold crank ? thanks
   / yanmar ym 1500 battery? #2
I forget the series but put the largest one your tractor will hold in there. mine is at the farm so I don't know.
   / yanmar ym 1500 battery? #3
I have a YM 2000, I bought my battery @ walmart, I think it is around 650 cold cranking amps. Hope this of some help. Take care.
ok guys it says only 300 crank on the battery that is on it so will have a meassure up see what will fit will update when i see what there is. thanks
   / yanmar ym 1500 battery? #5
Just measure and get the largest (capacity) battery that will fit.
I don't know if the same definitions are used in the UK compared to here, but I bought a 'Group 24' that fits in my slightly larger YM240 (YM2000).
Before that - when I bought the tractor I moved over the used battery from my wife's Subaru. It was smaller than a '24' but that worked fine to get the second four years of life out of that battery. I think the one from the Subaru is near universal across Honda, Toyota, etc.
Just don't make the mistake I made with my first replacement - the salesman told me a 'dual purpose' marine battery, intended for both starting and for running an electric trolling motor etc, was a good choice because they have less self discharge if not used for months. I discovered after a year or so that this type isn't built tough enough for the shock and vibration on a tractor, and had to replace it with an ordinary automotive battery.
o thanks for that im looking at heavy duty deisel at the moment will meassure and let you all know . thanks
   / yanmar ym 1500 battery? #7
Just replaced my batt. I think it's 650 cca. It cost me $105.00 which I thought was a little steep
yes im looking for a big cca on a battery not sure if thats expensive as we use pounds here not dollars.dose it fire it up quite fast?
   / yanmar ym 1500 battery? #9
It spins over at a good rate.I did replace my old cables with new ones (from starter to batt & the ground)
Case CX80C (A50123)
Case CX80C (A50123)
2023 Fat Truck 2.8C Amphibious AWD Off-Road Utility Vehicle (A51692)
2023 Fat Truck...
2014 Dodge Avenger Sedan (A51694)
2014 Dodge Avenger...
2012 TROXELL COMPANY  130 BBL VACUUM TRAILER (A52472)
2012 TROXELL...
2020 Utility Trailer Manufacturing, 53' Trailer (A52384)
2020 Utility...
2430 (A51248)
2430 (A51248)
