Yanmar year of making
   / Yanmar year of making #1
monzadriver
De Veen, Holland
Kubota B7100
Hello
My friend has an older Yanmar tractor, a smaller model.
Ar there lists i which i can find the year of production with help of the chassis-number ?
Greets Niels
   / Yanmar year of making #2
Tell us the exact Yanmar model number and we can tell you the years in which the model was in production.
   / Yanmar year of making #4
Yanmar YM1401​
Yanmar YM1401 tractor photo
1979 - 1981
Compact Utility tractor
Production
Manufacturer:Yanmar
Type:Compact Utility tractor
Variants
YM1401:2WD
YM1401D:4WD
Yanmar YM1401 Power
Engine:13.8 hp
10.3 kW
Yanmar YM1401 Engine
Yanmar 0.9L 3-cyl diesel
Mechanical
Chassis:4x2 2WD
4x4 MFWD 4WD
Cab:Open operator station.
Transmission:6-speed gear
Power Take-off (PTO)
Rear RPM:540 (1.375)
Engine RPM:520@2400
862@2400
1300@2400
Dimensions & Tires
Wheelbase:49.4 inches
125 cm
Weight:1080 to 1168 pounds
Front tire:4.50-10
2WD Rear tire:8-16
Electrical
Ground:negative
Battery volts:12
Battery AH:45
Page information
Last update:May 3, 2018
Copyright:Copyright 2021 TractorData LLC
Contact:Peter@TractorData.com
Thanx.
But that page i already discovered.
It gives an idea of the year.
But not the exact year
   / Yanmar year of making #6
Serial Number?
   / Yanmar year of making #7
So, it's a
1979
1980
1981 (edited to correct typo)
A 3 year spread isn't close enough for you?
   / Yanmar year of making #8
I will say it is a 1980, give or take a year.
   / Yanmar year of making #10
Your steel rims on the 1401 are stamped with the date they were made.
Clean them up real good and look for the numbers. They might be hard to find if the wheels have been painted a few times.
2014 Ford Escape SUV (A55853)
2014 Ford Escape...
(1) KUBOTA TRACTOR RIM (A57192)
(1) KUBOTA TRACTOR...
2002 Isuzu NPR-HD Box Truck (A56858)
2002 Isuzu NPR-HD...
KBH Mule Boy (A53317)
UNUSED PROFESSIONAL X2600A ELECTRIC CONCRETE MIXER (A57193)
UNUSED...
Versatile 260 (A53317)
