YANMAR Trouble
   / YANMAR Trouble #1
JonSpinosa
Baldwinsville, New York
Hi guys, I have a question for you mechanics. I have a John Deere F932 with a 3 cylinder Yammar gas engine. Sometimes when I start the engine it sounds and feels like it is not running on all 3 cylinders and seems like it is not firing properly. When I rev up the engine you can just hear and feel that it is running rough. However, it does not do it all the time. It seems like every other time I run the engine it does this. I did change the plugs and it seemed to help for awhile. Sometimes it can smell funny as if the combustion process was not right. Do you guys have any thoughts. Thanks for your help!
   / YANMAR Trouble #2
I used to have a Japanese motorcycle that did what you are describing. The problem turned out to be a bad ignition coil wire. Just a thought.
   / YANMAR Trouble #3
Did you check the fuel injectors, fuel line and fuel quality yet? Ever run it out of fuel?
Just some initial thoughts...
   / YANMAR Trouble #4
Have you change the fuel filter,also start w/ fresh fuel.
Thomas..NH /w3tcompact/icons/wink.gif
   / YANMAR Trouble #5
In my Deere manual under the heading of Uneven Combustion Sound/Troubleshooting the causes listed are as follows:
Fuel -water
Fuel -wrong type
Fuel Injectors-uneven volume
Fuel Injectors-poor pattern
Clogged or Leaking Air Filter
Clogged Exhaust Pipe
Sounds like your heading down the right track here.
DFB
   / YANMAR Trouble
Thanks for the help guys. I suspected it to be something in the ignition system so I decided to purchase 3 new coils with spark plug wires and it solved the problem. The Yanmar 3 cylinder gas engines each have a coil with an attached spark plug wire. I decided to purchase each coil at a price of $35.00 per coil and plug wire. I suspected it to be one of those coils but did not know how to test each coil. I just figured buying all three would still be cheaper than taking it to a dealer. Thanks for your help.
   / YANMAR Trouble #7
Good move, buying all three. You just know that the second one will fail right after you get the machine running again /w3tcompact/icons/tongue.gif.
mark
   / YANMAR Trouble #8
I know it's moot at this point, but could you not remove each wire from the plug and do a visual check of the spark intensity to ground? Perhaps there is more to it though. With a digital ohm meter you can also check the resistance in the wires. Knowing what the resistance is can be confusing but a rule of thumb would be to check that the values are relatively close. This would be a guide provided not all the wires are bad. Of course, now that you have all new wires and coils, you are pretty well set and should be trouble free for some time. Rat...
2013 INTERNATIONAL WORKSTAR 7600 SBA 6X4 DUMP TRK (A51406)
2013 INTERNATIONAL...
2010 MACK MRU613 GARBAGE TRUCK (A51243)
2010 MACK MRU613...
CFG MH12RX Mini Excavator (A49461)
CFG MH12RX Mini...
Mayrath 10 x 32 Auger (A50514)
Mayrath 10 x 32...
2003 STERLING M6500 ACTERRA 11FT FLAT BED (A51222)
2003 STERLING...
2015 John Deere 310SL (A47384)
2015 John Deere...
