Yanmar tractor 2010d
/ Yanmar tractor 2010d #1
packrat17037
2010d yanmar
I have coolant in the transmission. Any help?
/ Yanmar tractor 2010d #2
They call the Trans. a Power Shift. Automatic basically. If it is the Transmission leaking power shift pump would be my guess, Regulator gasket or seals. I'm showing Fredricks should have everything for that model Power Shift.
It's the coolant getting into the engine oil and the transmission. Sorry I didn't state it correctly in my original post.
/ Yanmar tractor 2010d #4
Coming in the rear main bearing seal. I'd be looking at the Head gasket etc... Radiator staying full fluid? Is it super cold in your location,Freeze and break the block?. Pretty much rule out the Transmission itself. With Radiator fluid getting in it.
/ Yanmar tractor 2010d #5
You have to ask here in the correct location,
/ Yanmar tractor 2010d #6
I don't understand how coolant could get into the transmission. My YM2310 has a clutch between the engine and transmission. If coolant was leaking out of the block I cannot see how it could get into the transmission. Anyway, coolant getting into the engine oil could be a blown head gasket, a cracked block or head, or, since your engine is a wet sleeve type engine, failed seals for the sleeves can let coolant get into the oil. And are you sure there is coolant in the transmission oil? Maybe you are seeing coolant leaking out of the clutch housing. I have a YM2310 which is a similar tractor, bigger engine but same transmission and I cannot envision any way coolant could get into the transmission. But I could be wrong and don't mind being corrected.
Eric
/ Yanmar tractor 2010d #7
It could be your rear main seal is leaking in the clutch housing so it looks like its coming from the transmission.
But its antifreeze??
/ Yanmar tractor 2010d #8
Some engines have freeze plugs in the back of the block inside of the bell housing and hidden behind the flywheel.
/ Yanmar tractor 2010d #9
#4 reply sure seems to be the common a opinion!
2006 Volvo VNM S/A Day Cab Truck Tractor (A61573)
2006 Volvo VNM S/A...
KOHLER 275ROZD71 DIESEL GENERATOR (A64281)
KOHLER 275ROZD71...
213135 (A64276)
213135 (A64276)
UNUSED SDLANCH 14' PARTING IRON GATE (LION SCENE) (A64281)
UNUSED SDLANCH 14'...
Bobcat S66 Skid Steer (A63688)
Bobcat S66 Skid...
2022 Weber CR 5-II HD Reversible Plate Compactor (A61572)
2022 Weber CR 5-II...
