yanmar tractor 165 no oil pressure
   / yanmar tractor 165 no oil pressure #1
nut123
gainesville ga.
yanmar 165 d
hi I need some help on why there is no oil pressure I put all new bearings a new oil pump and it will not pump a drop. please help me if you can thanks.
   / yanmar tractor 165 no oil pressure #2
Sometimes loosening the oil filter and give it a short crank on the starter is enough to draw the oil into the pump - this has worked for me a couple times ... Good Luck
hi I have rebuilt engine new bearings new oil pump but I still have no oil pressure
   / yanmar tractor 165 no oil pressure #4
It is possibnle that our oil lsystemis air locked and needs to be purged by loosening the oil filer to let it bleed out the air, as Dan noted above. It is also possible that you have a bad drive gear on your oil pump or your camshaft (or whatevr drives the oil pump) isn't turning. Start by trying to bleed out any air then let usknow what happens.
   / yanmar tractor 165 no oil pressure #5
Did you fill the filter with oil before installing?
2011 Ford Crown Victoria Sedan (A51694)
2011 Ford Crown...
https://www.accessnewswire.com/newsroom/en/healthcare-and-pharmaceutical/slimjaro-vs-burnjaro-reviews-a-comprehensive-analysis-of-benefits-and-1044755
https://www.accessn...
2018 Case TR270 High Flow 2-Speed Compact Track Loader Skid Steer (A51691)
2018 Case TR270...
300 GALLON PORTABLE FUEL TANK (A51247)
300 GALLON...
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER TRUCK (A53426)
2016 FREIGHTLINER...
2015 JOHN DEERE 310K BACKHOE (A51406)
2015 JOHN DEERE...
