Yanmar tiller
   / Yanmar tiller #1
OhioGuy
Platinum Member
Northeast Ohio
Ford 1220, Case 245, Cub SZ60, Cub 2284
I bought a 1301 in the spring and got my first chance to put it to work today. My last attempt to till, I raised the tiller binding the PTO shaft and broke the universal. I cut down a new one this weekend and also made a shorter toplink out of an old piece of steel. It tilled really well but I have a couple of questions.
I tilled a fairly level piece of ground and ended up with some valleys that tilling again didn't remedy. Was that a result of uneven speed?
Also, not having a shearpin really makes me nervous. Today I was moving super slow and it seems like a couple of roots and stones caused some pretty serious vibration back there.
Any suggestions, my biggest fear is damaging the tractors PTO.
Thanks,
Curt
   / Yanmar tiller #2
I have four foot Yanmar tiller for about five years with no problems. The rear wheels leave tracks, but I just use the to plant rows. I kept the center link from my yanmar when I bought the Kubota and it fits perfectly.
   / Yanmar tiller #3
I have found that since my tractor doesn't have draft control that the tiller does the opposite of the front wheels. However, I don't recall having any real valleys except at the end of passes. I also usually cross till to help eliminate spots that are tilled shallow due to the front being "down".
To keep from binding up my pto shaft I made a "stop" which I put on my 3pnt control to keep from raising the tiller too high.
I don't have a shear pin or clutch either and have found that so far, knock on wood, it tends to simply climb or jump over obstacles.
   / Yanmar tiller
I replaced my lift arms with a set approximately 6" longer and it corrected the PTO shaft binding problem . I can lift to maximum height without binding. I use my standard length arms for my RM 59 and rotary cutter.
Curt
2005 Chevrolet Uplander Van (A51694)
2005 Chevrolet...
2014 Dodge Ram 5500 Chevron Wrecker Tow Truck (A51692)
2014 Dodge Ram...
2020 COLOMBO TM LOT IDENTIFIER 202 (A53084)
2020 COLOMBO TM...
UNUSED MOWER KING SSFCAG Y HD HYD AUGER (A51248)
UNUSED MOWER KING...
