Yanmar Serial Numbers
   / Yanmar Serial Numbers #1
sirgknight
South Georgia
Early model YM1700
The serial number on my tractor is 2TR1707014. Can someone tell when it was manufactured? Thanks.
   / Yanmar Serial Numbers #2
That is actually your engine model number and serial number. The tractor model is a YM1700. Depending on your version, it was built in the mid to late 70's. Assuming the wheels are original equipment for that tractor, you can usually find a date code stamped into them. 4-76 would be April 1976, etc.
Hope this helps,
Aaron
Parts@HoyeTractor.com
(940) 438-0386
Thanks, I'll check it out.
   / Yanmar Serial Numbers #4
I have a Yanmar YM2000 with this serial code [or code in imprinted in cast iron below seat] .... YM2000-04811
Can you tell me when this one was made ? Please.
It also has this on the imprinted in the metal on engine - 5 (above) then under 4-11-28
Thanks so much .. hope you can help ..
gdtractor
   / Yanmar Serial Numbers #6
You cannot determine the manufacturing date from a serial number.I have been reading about the supposed date stamped into a wheel for many years, but have never read of anyone actually seeing it.
   / Yanmar Serial Numbers #7
Norm, my two YM186D's have Spring 1983 dates stamped in all the wheels. (5-83 for example). I think the manufacturing run was 1980 ~ 1985 so those numbers seem credible.
I agree Yanmar's chassis and engine numbers only define which upgrade level the tractor belongs to, nothing more.
   / Yanmar Serial Numbers #8
Where do I look on the wheels for the date , it has been repainted ?
Thanks , Joe
   / Yanmar Serial Numbers #9
The date is stamped into the steel on the outside part of the wheel as they were positioned on the axle from the factory. Look closely, and you will see it. There is no definite correlation between that date stamp and the date that the tractor was manufactured. However, it will give you an approximation. Who knows how long the wheels were sitting in inventory after being manufactured by the vendor. The only definite conclusion that can be drawn is that the tractor was manufactured AFTER the date stamped on the wheels (assuming that the wheels are original to your specific tractor). I have been told that Yanmar did not keep records to tie a serial number to date of manufacture. Sounds strange to me, but I can only go on what I have been told by those who have been directly involved with Yanmars for many years.
   / Yanmar Serial Numbers #10
I think they have the information but won't share it. That lawsuit that preceded them going after the gray market importers cited the history of that specific tractor.
Just guessing but I think they de-emphasize model year, consider it irrelevant, then sell by model instead, so anything they have for sale is a 'current model'.
80in HD Tooth Bucket with Side Cutters ONE PER LOT (A51039)
80in HD Tooth...
2019 Tico Yard Spotter Truck - Cummins Diesel, Allison Auto, Hydraulic Air Fifth Wheel, Cab w AC (A51039)
2019 Tico Yard...
5 Shank Inline Ripper (A50514)
5 Shank Inline...
KENWORTH W900 (A50854)
2019 Generac MLTS-1 2.4kW Towable LED Light Tower (A49461)
2019 Generac...
1266 (A50490)
1266 (A50490)
