yanmar seems to be skipping
   / yanmar seems to be skipping #1
buntrock
st matthews s c
yanmar 1700
I just repaired my Yanmar1700 replaced rings rod brngs head gasket,but now it seems to have developed a skip while running . It is not constant sometimes it does sometimes it doesn't.I did not tamper with injector pump or related mechanicals during repair.It idles as it should just at random while using tractor it skips.I installed new filters fuel oil and air and have primed,injectors several times.It has water pump,'Hoye Tractor," and new radiator oil pressure and temp gauges.Temp runs around 190 while operating and oil pressure around30 psi.Everything seems normal,have not checked compression however appears to have normal or adequate compression.Have added ,'Sea Foam," additive,recommended by local mechanic,but have noticed same random skip. Have less than 1hr on re-ring. Any suggestions?
   / yanmar seems to be skipping #2
There is a yanmar section in this forum group and the guys there might be able to help you out better.
The oil pressure seems low. My oil pressure runs about 50 psi when at about 190 - 200 deg.
Also check all the fuel lines from the fuel tank to see if brittle, they may have small cracks in them letting air in the system.
   / yanmar seems to be skipping #3
That really sounds like air being sucked into a fuel line.
Seafoam works great, but IMO only when used in a small tank like a 2 liter Coke bottle mixed %50 with diesel and the supply and return lines in the bottle.
   / yanmar seems to be skipping #4
How is that different than putting a 50% mixture in your tank?
Don't know what happened but no more skip!Used tractor couple Hrs yesterday in SC 95-98 degrees no problem.Must have a Gremlin messing with me!
   / yanmar seems to be skipping #6
Air. Air in the pump from incomplete bleeding. Works that way.
Mike
Wolverine Fork Extensions (A50515)
Wolverine Fork...
(9) 8' Treated Posts (A50515)
(9) 8' Treated...
2015 Freightliner Bucket Truck (A52128)
2015 Freightliner...
2011 Ford F-450 Crew Cab Omaha Service Truck (A50323)
2011 Ford F-450...
2008 CATERPILLAR 140M VHP MOTORGRADER (A51242)
2008 CATERPILLAR...
2013 Hyundai Azera (A50324)
2013 Hyundai Azera...
