buntrock
I just repaired my Yanmar1700 replaced rings rod brngs head gasket,but now it seems to have developed a skip while running . It is not constant sometimes it does sometimes it doesn't.I did not tamper with injector pump or related mechanicals during repair.It idles as it should just at random while using tractor it skips.I installed new filters fuel oil and air and have primed,injectors several times.It has water pump,'Hoye Tractor," and new radiator oil pressure and temp gauges.Temp runs around 190 while operating and oil pressure around30 psi.Everything seems normal,have not checked compression however appears to have normal or adequate compression.Have added ,'Sea Foam," additive,recommended by local mechanic,but have noticed same random skip. Have less than 1hr on re-ring. Any suggestions?
