Yanmar SB60R Front End Snow Blower
   / Yanmar SB60R Front End Snow Blower #11
I can't speak for the Case, but on the Yanmar it only takes a few minutes to remove the loader then about 15 minutes to hang the blower bracket, attached the blower/driveshaft and reconnect the hydraulics.
The drive shaft I'm referring to is one piece, with a slip yoke near the blower bearing and a locking yoke at the PTO. I'm going to try removing it and rotating it 90 degrees to see if anything changes.
Thanks for the responses.
   / Yanmar SB60R Front End Snow Blower #12
Once you get a chance to use that blower on some heavy snow, please throw a quick video up here. I'd like to see the SA425 cast some snow.
   / Yanmar SB60R Front End Snow Blower #14
sailor lou
If so... where did you find the installation procedure for mounting the snowblower. I am working on the possible deal for a SA325 with the SB52 Blower and a Broom attachment
   / Yanmar SB60R Front End Snow Blower #15
Even as it's a small CUT, the SA425 has the largest for the rear wheels. The smaller SA models can't use a PHD due to the really small rear wheels.
bmaverick
I guess I do not understand PHD will you help me out with that please, I am close to ordering my SA325
   / Yanmar SB60R Front End Snow Blower #16
Red Pepper,
I purchased the snowblower new so it came with all the mounting hardware, hydraulic lines and instructions. I have the SB60 so it's probably different on the SB52. I've had good luck contacting Yanmar directly with with question like this, it may be worth a try.
   / Yanmar SB60R Front End Snow Blower #17
bmaverick
PHD is abbreviation for a Post Hole Digger. Your SA425 has the tallest rear wheels in the SA series, so you can attach and operate one. Likewise with the taller snow blowers.
Did you fill the rear tires with RV/Marine pink stuff winterized coolant? This is more pet safe and will not corrode the rims nor degrade the rubber tires. Having this will add to the traction the SA425 will need when plowing snow with wetness.
   / Yanmar SB60R Front End Snow Blower #18
Red Pepper,
see attached
  • YANMAR SB60R SB60C v3.pdf
   / Yanmar SB60R Front End Snow Blower #19
Thank you for the reply. The deal with the dealer fell through. Somewhat of a part time sales person did not follow through with emails and questions so I told them I will seek a dealer else where or look for a private sale
   / Yanmar SB60R Front End Snow Blower #20
I did end up picking up a snow removal unit for this coming season. It is a 1995 Simplicity Sunstar that has been gone through according to the gentleman that used it for the past 5yrs or so.
2016 Ford F550 4x4 Bucket Truck with Altec AT41 - 46FT Rotating Bucket and Jib Winch (A55302)
2016 Ford F550 4x4...
2018 Volvo MCT 110C (A55272)
2018 Volvo MCT...
EXCAVATOR RIPPER (A58216)
EXCAVATOR RIPPER...
2009 CHEVROLET SILVERADO 1500 (A58214)
2009 CHEVROLET...
2015 TEXAS PRIDE TRAILER  30 FLATBED GOOSENECK TRAILER (A58216)
2015 TEXAS PRIDE...
1997 Generac T/A Towable 175kW Diesel Generator (A56857)
1997 Generac T/A...
