Buying Advice Yanmar mechanic please help
/ Yanmar mechanic please help #1
fireemann
Bronze Member
southeastern Ohio
I’m looking for someone to help me figure out a Yanmar 3tnv84. It’s non turbo and in an ihi mini hoe. The engine was rebuilt with new sleeves pistons and rings. Pump was sent out and checked as well as injectors. I got it to run but can’t figure out why it’s not making power as it should.
/ Yanmar mechanic please help #2
Fuel timing? What about valve train? Checked timing there and adjusted the valves?
James
/ Yanmar mechanic please help #3
Were the shims under the pump reused.?? I hope u didn’t throw them out..
Have u gone to the pump to make sure the throttle assembly is going to wide open and hitting the stop screw.??
So had all the locals that know diesels mess with it. We’ve played with injection timing and have been from 2 teeth retarted to 9 teeth advanced. It will start lugs under strain. Smokes white and smells strong of fuel under load smoke gets dirty but not black.
As far as I know shims are the same. Had pump and injectors run at Columbus diesel in ohio.
/ Yanmar mechanic please help #6
Did they send a report back with the pump and injectors?
Are all fuel filters new?
It throttles up just not sure about it hitting the stop screw.
2025 JMR 4x8 Forklift Safety Basket (A61572)
2025 JMR 4x8...
2014 Ford F-150 4x4 Crew Cab Pickup Truck (A61573)
2014 Ford F-150...
Rake Mini Excavator Attachment (A61572)
Rake Mini...
2025 Unused SDLGC80 Electric Golf Cart (A64194)
2025 Unused...
EZ Go TXT Golf Cart (A61166)
EZ Go TXT Golf...
WHITE 2-60 TRACTOR (A63291)
WHITE 2-60 TRACTOR...
