Yanmar joystick control valve for front end loader
   / Yanmar joystick control valve for front end loader #1
dane59432
Conrad, Montana
Yanmar 3110D
Had a little mishap with my Yanmar 3110d today. One of the plungers in the joystick control valve broke an ear where the heim joint bolts through . Can anyone tell me a part number for a complete joystick valve assembly that will be a direct interchange? Do they make such a thing? Called a Yanmar dealer in Georgia who said there is no way to confirm which one it is because it is a Gray market tractor with the V-Tek V3 loader (and therefore no literature to look it up). Anyone run into this? Is there even a direct replacement avail.? Thanks in advance :)
P.S. Hoyle has one (part number HLV-101) that they claim is for MOST yanmars but they are out of stock and also state that it will not have the correct "float" feature (not sure if that can cause any issues). I am looking (ideally) for something more direct replacement. :anyone:
   / Yanmar joystick control valve for front end loader #2
I know this post is from 2017, but curious if you found a replacement? My 阻oystick doesn稚 match the threads into the female end. I was looking for a replacement, but might have to just use some thread locktite to keep it from coming out.
   / Yanmar joystick control valve for front end loader #3
You should be able to go to a shop that makes hydraulic hoses and either (worse case) have a new hose made with correct fittings or get adapters to convert one thread to the other (best case) they may or may not have the adapter in stock but should be able to order one.
2011 Ford F-350 Knapheide Service Truck (A55852)
2011 Ford F-350...
17101 (A55787)
17101 (A55787)
2021 CATERPILLAR CB2.7 DBL DRUM TANDEM ROLLER (A52705)
2021 CATERPILLAR...
2012 Chevrolet Silverado 3500 HD Enclosed Service Truck (A53422)
2012 Chevrolet...
UNUSED SWICT 72" QUICK ATTACH BUCKET (A54757)
UNUSED SWICT 72"...
2020 GENIE TZ-34/20 ELECTRIC PORTABLE SCISSOR LIFT (A52705)
2020 GENIE...
