Yanmar Grease Fittings
   / Yanmar Grease Fittings #1
john_leslie
Tacoma, WA
Yanmar FX32D
I dont know how to do a search on here. Someone has probably already addressed this, but I cant seem to figure out what size my zerks are.
I tried metric and they dont fit. SAE either, although 1/8" NPT seems close.
What the heck am I dealing with here?
   / Yanmar Grease Fittings #3
There are some Japanese standard parts I know, I'm not sure though? The o rings in these tractors are Japanese spec. There not metric or SAE. Sometimes you can get one or the other ti work but for a critical one you need to get the correct japanese o ring the other will cut or blow out.
   / Yanmar Grease Fittings #5
I hit GF-6 twice on my old parts book. Grease fitting 6mm. is my guess? 2wd Front axle spindle. Fredricks. No Models listed. Repl.194151-11480 though.
Thanks Aaron I was looking them up!!!:) Slow I know...........
It may be that british thread. Very close in size to 1/8 NPT
   / Yanmar Grease Fittings #7
You could look here;
   / Yanmar Grease Fittings #8
It may be that british thread. Very close in size to 1/8 NPTView attachment 800224
Back in the day when Metric/Standard was Really a Pita. I think 6mm is acctually bigger than 1/8NPT. It's the Thread size that's the Problem. Don't hold me to that! Thread tape worked to get Grease in a broken bad fitting. Happened all the time.Graphic equpiment. Even had a Russian press. Royal Zenith!! That one was tough to figure out when we first had it installed......................
   / Yanmar Grease Fittings #9
M6 x 0.75mm
   / Yanmar Grease Fittings #10
On a Yanmar it is probably BSPT thread. I don't know why but I only see BSPT threads on Japanese stuff. The 2 most common tapered pipe threads are NPT and BSPT. On a Zerk fitting if the thread is a tapered pipe thread it is most likely gonna be a 1/8 pipe thread. NPT, Natonal Pipe Tapered Thread, which is what you would see in America, will have a 60 degree thread form and for 1/8 pipe will have 27 threads per inch. BSPT, British Standard Pipe Tapered, will have a 55 degree thread form and 28 threads per inch. As you can see the threads are very close. For a Zerk fitting I don't really think using a BSPT in an NPT hole or the reverse will make any difference. I have done it more than once. My reasoning goes like this: The threads on Zerk fittings are usually quite soft or quite hard. So the fitting will either conform to the tapped hole or will make the tapped hole conform to the fitting. In either case you end up with a fitting that will not let grease out or water in. Of course it is best to use the proper thread. But if you can't find the proper thread then use some thread dope or Teflon tape and install the Zerk. This is just my opinion and is worth what you paid. Even though I have been doing this for years it is technically bad practice and I only do this for Zerks. I understand that it is bad practice and if I was doing a job for a customer I would insist on using the proper thread. But for my stuff I have interchanged threads and never have had a problem. I don't really like doing it but sometimes I have had to make do.
Eric
2015 Ford F-550 Godwin 184U Crew Cab Mason Dump Truck (A51692)
2015 Ford F-550...
Как зайти с телефона на кракен. kra39ac.cc  | Kraken зайти на площадку? как пополнить кошелёк? Правила диспута
Как зайти с...
Sterling AT (A55301)
ITEM LOCATION (A53084)
2009 KENWORTH T6 SERIES SLEEPER (A53426)
2009 KENWORTH T6...
