Yanmar FX17 2WD
   / Yanmar FX17 2WD #1
BretonTractors
FX17 Yanmar with powershift transmission.
I am stuck in a barn in the middle of France (Europe) trying to locate the correct oil for the powershift gearbox. So far Auto transmission fluid and ISO 46 hydraulic oil has been suggested. I should hate to use the wrong type and the local French tractor dealers are not interested once you mention Yanmar!
Any advice? Please
   / Yanmar FX17 2WD #2
jack oil, plain hydraulic fluid and iso 32/46/64 are deffinately out.
My old yanmar used a JD303 compatible generic UTF type fluid.. Also called tractor transdraulic fluid.. etc would probably be a safe bet. I'm sure it would move on jack oil.. and would move on ATF... but if i had to guess... I'd opt for UTF since it is spec'd for final drives, trannies, hyds.. power steering.. wet brakes.. etc.
Soundguy
   / Yanmar FX17 2WD #3
I have power shift on my 3110D .I use JD303 .Sometimes I use the off brand that list same as JD303.
   / Yanmar FX17 2WD
Thanks for your advice. The French JD is not the same as in the US but I have now found a filter and the oil. All I need now is a service manual...any ideas?
   / Yanmar FX17 2WD #5
I have read that some run the ( atf ) automatic transmission fluid in their powershift yanmars .
NEW Wolverine 36'' Skid Steer Grapple Bucket (A53002)
NEW Wolverine 36''...
New Skid Steer Attachment Plate (A53002)
New Skid Steer...
GORBEL EASY ARM LIFTING ARM (A52472)
GORBEL EASY ARM...
1994 Thomas Built SAF-T-LINER (LOW MILES, CUMMINS, ALLISON) (A52748)
1994 Thomas Built...
2015 Jeep Wrangler Multipurpose Vehicle (MPV), VIN # 1C4BJWEG5FL757630 (A51572)
2015 Jeep Wrangler...
PRESSURE WASHER GAS (A52472)
PRESSURE WASHER...
