Yanmar F16d ring and pinion
   / Yanmar F16d ring and pinion #1
jarrod77
Everton Mo
yanmar f16d
Help please new member. I purchased yanmar with bad rear pinion gears.I have had problems finding part.Any help would be appreciated. Thank you, jarrod
   / Yanmar F16d ring and pinion #2
Unless someone has 1 they are parting out. You might have to get someone to order these parts from japan if they are still available
   / Yanmar F16d ring and pinion #3
The F16 ring & pinion is no longer available new. I have a used one.
   / Yanmar F16d ring and pinion #4
Lens 12
do you by a slim chance still have that ring and pinion gear ?
   / Yanmar F16d ring and pinion #6
the lead was good but for $750.00 . excessive pricing
   / Yanmar F16d ring and pinion #7
I dont know if there that hard to find....that may as well be the going price.
I seem to remember back when i was going to regear my 4wd old pickup and decent ring and pinion was $350 for the common GM 12 bolt rear end which there was probably millions made and hundreds of thougsands still in service. this is a specialty item for a tractor that is almost 30 years old that is not in its parent country and that was never made in that quantity.
I am not saying i like that price but that may as well be the price.
   / Yanmar F16d ring and pinion #8
That is the best you will do. A new set for an FX24D is $695 and they are available. If your serious about repairing it you better grab it before someone else does. Just an opinion. :2cents:
   / Yanmar F16d ring and pinion #9
I paid $ 800.00 for the tractor and if I add $750.00 thats $1,550.00 that I would have in the Yanmar F16D 4X4
is that top on what that tractor would bring ?
No accessories came with the tractor
   / Yanmar F16d ring and pinion #10
I would think it would bring a little more than that or I guess you can parts it out. Does it have a loader? Just don't think you will do much better on the gears. Do you already have it torn down?
2016 Ford Explorer AWD SUV (A51694)
2016 Ford Explorer...
2018 FORD TRANSIT T250 CARGO VAN (A52577)
2018 FORD TRANSIT...
2014 Yale 3 stage 8500lbs lift solid tire forklift (A52748)
2014 Yale 3 stage...
2010 KMC 3376 Peanut Combine (A52748)
2010 KMC 3376...
2010 MQ POWER 25KW GENERATOR (A52472)
2010 MQ POWER 25KW...
