Snow Equipment Buying/Pricing yanmar cbl 40
   / yanmar cbl 40 #1
mdmj
buffalo ny
yanmar cbl40
I have a yanmar cbl 40. Wondering if it will handle 72" snowblower? It's a 40 hp tractor but only rated 24hp at the pto. Why does this tractor have such a decrease in hp at the pto? Any info would be appreciated. Thanks.
   / yanmar cbl 40 #2
:welcome:
To the forum. I can't find that model, cbl40, anywhere but I did notice that several Yanmars have a wide difference in HP between engine and PTO.
   / yanmar cbl 40
thanks.
   / yanmar cbl 40 #4
A hydrostatic will at that horsepower but probably not a gear tractor by virtue of the speed control factor
   / yanmar cbl 40 #5
I ran a 60" 3pt blower for years with a Kioti CK20Hst, rated at 17hp on pto. With HST its easy to adust speed to snow load , heavy wet snow slow down and take a smaller bite.
Technically most literature says 5hp per foot of cut, so I should have had a 25 or 30hp tractor but never really had a problem. So IMO one foot more should be no problem for you.
   / yanmar cbl 40 #6
Those are nice tractors,:thumbsup:
I don't see any problem either with a 6 foot blower,
will a five footer cover your rear wheels?
   / yanmar cbl 40 #8
The CBL-40 is a very rugged machine but closer to 35 net hp than 40. It has a larger hydraulic pump than a CUT of that hp and twice as much weight to throw around, so I don't think it should be surprising that 24hp is the leftover PTO output after accounting for the parasitic loss. Unfortunately I don't have any snowblower insight to offer, but I think you'd have one tank of a snow-plow platform if you ever decided to put a front blade on it--almost 8000 lbs of weight, wow!
   / yanmar cbl 40
Thanks for all the info. I borrowed a 72" blower, it worked fine.
   / yanmar cbl 40
no i borrowed a 6 footer it worked fine
2005 CATERPILLAR 12H MOTOR GRADER (A51406)
2005 CATERPILLAR...
2018 DODGE RAM 2500 (A50854)
2018 DODGE RAM...
Flat Deck Trailer (A50322)
Flat Deck Trailer...
1985 Toyota Pick Up Truck (A50515)
1985 Toyota Pick...
2018 GENIE GTH-636 TELESCOPIC FORKLIFT (A51242)
2018 GENIE GTH-636...
12 Ft Enclosed Trailer (A50324)
12 Ft Enclosed...
