Yanmar Alternator Problem
/ Yanmar Alternator Problem #1
QBH
Bronze Member
Alachua, FL
Yanmar 2210D, Kubota BX25D, Gravley PM260Z ZTR
I have had a problem with the alt and battery on my YM2210D for a while now. Last week, I replaced the alternator and battery. I measured the battery voltage with the engine off, and it is about 12.4. With the engine running, even at high RPMS, the voltage is only about 12.8. It seems like it should be higher, shouldn't it?
BTW, the belt is good and tight.
Any thoughts or suggestions?
Thanks,
Larry
/ Yanmar Alternator Problem #2
Voltage is on the low sides for both on engine off and running. The battery should read in the range of 12.75 to 12.90 when fully charged. When engine running and tested on battery or alternator it should read somewhere in the 13.25 volts or higher. Check your grounds on tractor frame and battery and scrap clean for a re-check on voltage.
DevilDog
Good thought on the ground. I will check that. I am checking the battery voltage right on the (brand new) battery posts, so I know that is right, but I dont know that it is getting a good ground. Thanks.
2022 EZ-GO ELITE...
2018 GMC Sierra 1500 SLE 4x4 Crew Cab Pickup Truck (A64556)
2018 GMC Sierra...
2020 CATERPILLAR 316FL EXCAVTOR (A65053)
2020 CATERPILLAR...
2015 Ford Transit 250 Cargo Van (A64556)
2015 Ford Transit...
2005 Lexus ES 330 Sedan (A64194)
2005 Lexus ES 330...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
