Yanmar 3T80J cylinder head torque specs?
   / Yanmar 3T80J cylinder head torque specs? #1
StxRancher
Edinburg
JD 450C dozer
I'm replacing the head gasket. Can anyone help me with these torque specs and rockers?
   / Yanmar 3T80J cylinder head torque specs? #2
I can tell you what it is on a 3T80U-N. Stages of 29, 58, 72-79 ft lbs. Cylinder head assist bolts 22 ft lbs. Rocker arm support nuts 40 ft lbs.
Would it be the same?
   / Yanmar 3T80J cylinder head torque specs? #4
I believe so but no warranty on my end.
   / Yanmar 3T80J cylinder head torque specs? #5
The 3T80J is found in the John Deere machines. I know, I once had a JD850. I have virtually the SAME engine now in my YM2610, closer if it's a YM2500.
On the Yanmar Tractor Owners Group site, link in my sig next to the flag, there is a TM1192 Service Manual you can get for FREE. It should have those specs you are looking for. Bet it's about the same as Winston listed.
The 3T80 engine comes in a few variants. Just depends on where & what air cleaner is used, if the thermostart is a manual fill or hosed to the diesel tank, early models no cylinder sleeves like the later variants and what exhaust pipe is used. Not much more really.
Don't be shy, we like to hear more about your Yanmar painted JD green. Is yours a JD850, JD750, HC900 or another?
I just joined the yanmar tractor owner group, Im trying to find your link. I can click and see your messages, but i dont see a flag or signature
   / Yanmar 3T80J cylinder head torque specs? #7
On the site with FireFox, it's off of the WIKI page lower left column. Then Pick RESOURCES PAGE. Should be in the top of the page. The WIKI is access for community members only. ;)
   / Yanmar 3T80J cylinder head torque specs? #8
What machine do you have that has this engine. I see the John Deere manual referenced never mentions Yanmar model numbers.
   / Yanmar 3T80J cylinder head torque specs? #9
   / Yanmar 3T80J cylinder head torque specs? #10
Please may I have the Torque specs for rebuilding a Yanmar 3t80-uj on a Deere 750 from 1982.
We are rebuilding it.
Giyi Mini Auger (A57149)
Giyi Mini Auger...
2017 John Deere 5075E (A57148)
2017 John Deere...
2015 Ford Fusion Hybrid Sedan (A56859)
2015 Ford Fusion...
UNVERFERTH 18' FIELD CULTIVATOR (A52708)
UNVERFERTH 18'...
2006 Magnolia Dry Fertilizer Tender Trailer - Dual Stainless Compartments, Hydraulic Doors (A56436)
2006 Magnolia Dry...
2025 IRGC40 Mini 3 60v Electric Tricycle (A56859)
2025 IRGC40 Mini 3...
