yanmar 33tne88
/ yanmar 33tne88 #1
shawnsd412
mt carmel, pa
Bush hog d-412
My Mini-ex has a 3 cylinder yanmar 33tne88. It wont start without help from gas, starting fluid or wd-40. I cleaned the tank, changed the filters, new fuel lines, new lift pump, new head gasket and valve job, and new fuel injectors, and it still wont start. When it does run it doesn't smoke at all, Im thinking i need the injection pump rebuilt but I am stumped and want to fix it so i can sell it. It is a gehl model 292 year 2000. i would appreciate any help
/ yanmar 33tne88 #2
You might have some better luck in the "construction equipment" section.
/ yanmar 33tne88 #3
Does the engine use glow plugs or an intake heater?
Also, does it crank fast enough? Meaning you battery may not be putting out the amps.
/ yanmar 33tne88
Intake heater, turns over fast. it slowly started to act up . at first if i would jump it, it would start. but i have since put in a new battery and no luck
Heavy Duty Steel Baskets (A65579)
Heavy Duty Steel...
(2) 30 Yard Roll Off Dumpsters (A65579)
(2) 30 Yard Roll...
2021 Kubota SVL75-2 Track Loader (A63689)
2021 Kubota...
2017 International 4300 Box Truck (A62613)
2017 International...
2017 Ram 5500 Bucket Truck (A63689)
2017 Ram 5500...
2015 FREIGHTLINER CASCADIA 6x4 T/A DAY CAB TRUCK TRACTOR (A59906)
2015 FREIGHTLINER...
