yanmar 33tne88
   / yanmar 33tne88 #1
shawnsd412
mt carmel, pa
Bush hog d-412
My Mini-ex has a 3 cylinder yanmar 33tne88. It wont start without help from gas, starting fluid or wd-40. I cleaned the tank, changed the filters, new fuel lines, new lift pump, new head gasket and valve job, and new fuel injectors, and it still wont start. When it does run it doesn't smoke at all, Im thinking i need the injection pump rebuilt but I am stumped and want to fix it so i can sell it. It is a gehl model 292 year 2000. i would appreciate any help
   / yanmar 33tne88 #2
You might have some better luck in the "construction equipment" section.
   / yanmar 33tne88 #3
Does the engine use glow plugs or an intake heater?
Also, does it crank fast enough? Meaning you battery may not be putting out the amps.
   / yanmar 33tne88
Intake heater, turns over fast. it slowly started to act up . at first if i would jump it, it would start. but i have since put in a new battery and no luck
TEYME 2000 E0L0 GTE10 LOT NUMBER 228 (A53084)
TEYME 2000 E0L0...
2018 JLG 3246ES 32ft Electric Scissor Lift (A51691)
2018 JLG 3246ES...
2012 International DuraStar 4400 Service Truck with Crane, VIN # 1HTMKAAN2CH076971 (A51572)
2012 International...
Quick Attach Skid Steer Plate (A51573)
Quick Attach Skid...
John Deere S780 Combine (A53342)
John Deere S780...
2005 Sterling Acterra Tender Truck (A53472)
2005 Sterling...
