Yanmar 3 cyl 3TNE68C
   / Yanmar 3 cyl 3TNE68C #1
Wherewolf
Oregon
Many
When I aquired this engine, it had no wiring harness or relays. I can handle the wiring for the fuel solenoid, starter, and temp/oil senders. What I'm wondering about is the glow plugs. Do I need a relay? or can I wire 12 v to a push button type switch and on to the plugs so they only heat while you're holding the button in? Is there anything about the relay that reduces the voltage/amps to the plugs? This engine uses the NGK y702R which according to NGK is a self-regulating glowplug, hotter it gets, the less current it pulls, so I think I just have to provide it power.....
Anyone have any input/advice?
Many Thanks!
Wherewolf
   / Yanmar 3 cyl 3TNE68C #2
You do not need the relay. You just need a switch heavy enough to carry enough current to provide the glowplugs. I don't know how much amperage the glowplugs pull so I can not tell you the rating of the switch that you need.
I just did this same thing to my Yanmar excavator with a 3T80L engine and it used a CH14079 glowplug. I ran #12 gauge wire and used a Briggs-Stratton push starter switch and it works great. The glowplug only works while you hold the switch which you said.
Hope this helps and Good Luck
Many Thanks - I think mine pull about 45 amps each for a few seconds, then drop down to about 8 amps per. I understand that the danger to glow plugs seems to be over voltage, so maybe I should put some type of resistor in the circuit to knock it down to 11v or 12v max? I know a good battery usually shows around 13.5v....
Wherewolf
(1) HD 24ft Free Standing Corral Panel with 7ft Gate (A51573)
(1) HD 24ft Free...
2022 CATERPILLAR 980 WHEEL LOADER (A51246)
2022 CATERPILLAR...
2016 Toro Groundsmaster 3505D 72in Rotary Mower (A51691)
2016 Toro...
https://www.globenewswire.com/news-release/2025/05/08/3077245/0/en/Nerve-Calm-Complaints-Investigated-2025-User-Reviews-Tested-Verified.html
https://www.globene...
2007 FREIGHTLINER BUSINESS CLASS M2 T/A DUMP TRUCK (A51406)
2007 FREIGHTLINER...
2004 JOHN DEERE 5205 TRACTOR (A51406)
2004 JOHN DEERE...
