YanMar 2210 Factory Crack spec's???
   / YanMar 2210 Factory Crack spec's??? #1
Strayhorn, MS
Yanmar
YanMar 2210 Factory Crack spec's??? Does anyone know what the factory Crack specs are for a 81 2 Cylinder 2210 Tractor. Also if its handy I would also like the spec's on the cam and rods.. Thank You in advance.:cool2:
   / YanMar 2210 Factory Crack spec's??? #2
According to Hoye's parts the 2000 and 2210 use the same crank and rods so here is what the I&T manual shows for the 2000.
Thank You! Going to go and see about get the crack turned, its a long shot but I have a contact at Bullet racing cams and they can turn it as long as its not cut to deep for 185.00 verses 450.00 for a new one.
Thanks Again!
   / YanMar 2210 Factory Crack spec's??? #4
According to available bearings they can turn the crack .030".
   / YanMar 2210 Factory Crack spec's??? #5
That's about right since my John Deere mechanic said the same thing for my Yanmar 3T80 in a JD-850. Are we talking crack or crank here :D
   / YanMar 2210 Factory Crack spec's??? #6
I kept seeing "crack", so assumed it must be some type of code.
   / YanMar 2210 Factory Crack spec's??? #8
Wife says I need to readjust my "spenders" because I am showing more crack. Other wise the felons at the end of the road, could educate the rest of us on "crack".
   / YanMar 2210 Factory Crack spec's??? #9
What I thought also. I know with the new Fad of Wearing your your Draws down around your Hips. But 30" of Crack ? That did sound a little much or either on it.:p
2002 Fleetwood Expedition 36ft Motorhome (A51694)
2002 Fleetwood...
LIKE NEW 2023 Rhino 84in Reverse Rotation Rotary Tiller (A52748)
LIKE NEW 2023...
2005 INTERNATIONAL 4200 24FT BOX TRUCK (A52141)
2005 INTERNATIONAL...
John Deere M Tractor (AS IS) (A50774)
John Deere M...
2015 JLG Triple-L Flatbed T/A Trailer (A50324)
2015 JLG Triple-L...
