Yanmar 221 or Kubota 1870?
   / Yanmar 221 or Kubota 1870? #1
Catahoula
Indiana
None
Hi all. New member here. I am purchasing a sub compact and have narrowed it down to a Yanmar 221 or Kubota 1870 with FEL. Both have dealers near by. There is also a Mahindra dealer nearly as close. I have 23 acres, mostly wooded and not accessible by tractor. There are approximately 2.5 acres that are open. I am having a new home built on the site. Primary use for the tractor will be re-grading the gravel driveway (It has been torn up pretty good by construction equipment), repairing the lawn (again, torn up by construction equipment) and light landscaping. After the construction project, it will be used primarily for snow removal, hauling firewood and ongoing landscaping and possibly tilling. It won't be used much, if at all for mowing. I've got quotes for both, with the Yanmar coming in about $700 higher. For that price, I gain a couple of horsepower and engine displacement. Suggestions? Any others I should be considering in the same price range? There is a Deere dealer in the area, but pricing is significantly higher. Thanks!
Well, the Mahindra max22 is now in the mix. Looked at one over lunch today and was very impressed. Falls between the two on pricing, with more power than the Kubota. Should do everything I need.
   / Yanmar 221 or Kubota 1870? #3
I really like the looks of the new little yanmars. Unfortunately they have poor dealer representation in my area. I'm also pro kubota since I own one and have a great dealer. The bx kubotas have a great track record but the 1870 is a little small compared to the yanmar and mahindra you're looking at. I think any of the three would make a very good tractor! If you like the mahindra and have a good dealer go for it!
   / Yanmar 221 or Kubota 1870? #4
The Mahindra MAX series is very High Value.
Exceptionally well engineered, excellent capability, favorable pricing.
Hard to beat!
   / Yanmar 221 or Kubota 1870? #5
Would suggest you look at the Kubota B series, not the BX models like the 1870. The BX line is an "estate tractor" model with less ground clearance and smaller size, optimized for mowing and grounds care; the B models are a bit bigger and have more clearance, would probably be a better choice for the work you describe. Having said that, should note my 9 year old BX has done its share of heavy work without problems and continues to amaze with its ability. Moving up to a B platform would probably shift the price point a little.
Thanks for the feedback. The Mahindra definitely seemed a little beefier than the BX series Kubota at a similar price point. I looked at the B series, but the prices went up in a hurry. I've always been a Kubota fan, but was impressed with the Mahindra tractors. The only thing I didn't care for was the "price up" to get the 0% financing, but it looks like everyone does that to some degree.
   / Yanmar 221 or Kubota 1870? #7
Don't make the mistake that many, many people make - i.e., buying a tractor that is too small. The best advice is to buy one size larger than what you think you need.
For working in the woods and hauling firewood, tilling, etc., I'd suggest looking at the next steps up in the Mahindra - specifically the Max25 and Max 28. The 28 is a larger frame size and seems quite a bit beefier from my limited seat time on one (just "test sitting" it, not working it).
   / Yanmar 221 or Kubota 1870? #8
Edit: Double post.
Thanks Pappy. That is my concern with the 1870. I'll have to give it serious consideration over the next couple of days. There are some great deals on the Kioti CK2510 right now and it offers a little more HP and a beefier frame. I don't have much experience with Kioti, but may try to look at them over the weekend. The downside is an hour trip to the dealership.
   / Yanmar 221 or Kubota 1870? #10
Check with the locals about the dealers. A good dealer is better than brand information. Also, what parts do they stock is important, particularly from overseas brands that don't have a US factory or distribution system. I am a Kubota fan, they are lightweight, but great quality. I have had 2 over the last 20 years and no problems other than self inflicted ones during that time with hard use.
2002 International 9200i Truck (A55218)
2002 International...
LOAD OUT AND SHIPPING (A54865)
LOAD OUT AND...
2013 Nissan Sentra Sedan (A53424)
2013 Nissan Sentra...
2019 John Deere 204L (A47477)
2019 John Deere...
2017 TROXEL 150 BBL ALUMINUM VACUUM TRAILER (A53843)
2017 TROXEL 150...
2025 JMR Tree Boom Skid Steer Attachment (A53421)
2025 JMR Tree Boom...
