Yanmar 2200 Key/Ignition
   / Yanmar 2200 Key/Ignition #1
DannyV
Santa fe, Texas
Yanmar YM2200
Well as you know there isnt much room on these tractor's for us big guys right..When I got on the tractor my knee hit the key and broke it off inside the ignition. I cant get the broken bit out. What do you folks suggest I do? Does somebody have a replacement ignition for a ym2200? Perhaps there could be a domestic ignition that would fit.Let me know ..Thanks
   / Yanmar 2200 Key/Ignition #3
Hey Danny, try this on ebay. 17 bucks + 6 for shipping: "Kubota Diesel Ignition Switch". used it on my F18D and it works perfectly.
   / Yanmar 2200 Key/Ignition #4
A $17 (+$6) ignition switch is hard to beat and I think the only way it gets better than that is what I did with my Iseki when it arrived in the same condition. I simply removed the switch (after carefully color coding the wires) and after removing the cap, carefully fished the broken piece out and made a new key from it. Later, I found that the key on my Yanmar actually fit and worked with the Iseki, although the keys looked entirely different (zigs and zags). I think the security is mostly our imagination.
   / Yanmar 2200 Key/Ignition #5
In regards to security, I have two keys on my tractor set, one for the tractor and one for the master lock used to secure the tractor to barn with 5/16 chain. As per usual after unlocking and giving the tractor the once over, I pop into the seat and start cranking. After raking the driveway and putting her back in the barn I looked down and realized that the masterlock key was in the ingition! Wow now I can unlock the "door" and drive around with the same key. Now I should mention that I have a Recon and the key says Isuzu on it... This function did come in handy when my 18 month daughter decided to play hide the tractor keys and I was able to use the backup lock key..
VT
   / Yanmar 2200 Key/Ignition #6
Don't know if it's true or not as I haven't tried but.........the place where I purchased my tractor said that any John Deere key would fit the ignition. [probably shouldn't say that too loud, lol]
It might be worth your while to take the ignition switch out, try to remove the broken key and see if you have a key on your key ring that will fit.
Gosh I wish I would of read this sooner. I ended up going to Hoye and purchasing a ignition switch. Once I removed my old ignition I come to realize the new one was not exactly the same as my old ignition. I didnt have my wires marked when I removed it and now I am searching for a diagram so I can properly connect the ignition switch. I got it to start but no lights or power to the dash. getting alot of rain here so I havnt really worked on it a few days so maybe its just a fuse rather than a crossed wired. But I am pretty sure I have a wire or two backwards.
   / Yanmar 2200 Key/Ignition #8
I got one at Auto Zone with 4 keys for $10.
   / Yanmar 2200 Key/Ignition #9
tnbowhunter said:
Don't know if it's true or not as I haven't tried but.........the place where I purchased my tractor said that any John Deere key would fit the ignition. [probably shouldn't say that too loud, lol]....
It is undeniably true that my Yanmar key works perfectly well in my neighbor's JD750 and his key works just as well in my YM2220.
UNUSED X-STAR 101" X 20' LOADING RAMP (A51243)
UNUSED X-STAR 101"...
UNUSED AGT ATK-B1000 CARLIFT (A51244)
UNUSED AGT...
2023 Cat 310 Excavator (RIDE AND DRIVE) (A50774)
2023 Cat 310...
Toro Workman Utility Cart (A51694)
Toro Workman...
2012 CATERPILLAR 279C2 SKID STEER (A51242)
2012 CATERPILLAR...
