Yanmar 22 hp 3TNA72UJ3
   / Yanmar 22 hp 3TNA72UJ3 #1
bwc
Atlantic Canada
JD 455
What equivalent Yanmar tractor model uses this engine? This is in a John Deere 455 heavy duty lawn and garden tractor. Thanks.
Brian
   / Yanmar 22 hp 3TNA72UJ3 #2
My YM1510D has a 3T72SA which I believe means that it has the same displacement, but I am not sure of the other letters. I do not see that any Yanmars have that "exact" engine model.
Mike Petersen
   / Yanmar 22 hp 3TNA72UJ3 #3
Looking in my manual for the F series, I don't see anything with same engine # but I suspect this engine is somewhat special for JD. And like with Mike's comments, the 72 is the bore in mm and was found on the F15 models, 3T72H-N. Likely engine HP is in the 17-18HP range. Don't see any engines with 3TNAxx designation but did see one model with 3TNB80-U that was used on the F18's.
For Yanmar, the first 2 digets of the model # is pto HP.
   / Yanmar 22 hp 3TNA72UJ3 #4
Maybe it's a Marine engine someone converted?
Thanks everyone. This is not a marine engine converted. It is an oem engine found in thousands of JD 455 lawn and garden tractors. I was just wondering for my own information if Yanmar built a tractor around this engine. This is a very reliable, fuel stingy, robust little engine which will go a long time when looked after. Thanks.
Brian
   / Yanmar 22 hp 3TNA72UJ3 #6
Typical Yanmar engine characteristics ;)
(INOP) 2005 BRODERSON IC80-3G 9 TON ROUGH TERRAIN CRANE (A51406)
(INOP) 2005...
Informational Lot - Financing (A53473)
Informational Lot...
Roller (A52377)
Roller (A52377)
1985 International 1754 Material Spreader Dump Truck (A51691)
1985 International...
2021 Ford F-250 XL 4x4 Ext. Cab Pickup Truck (A52377)
2021 Ford F-250 XL...
John Deere PT Land Leveler (A50123)
John Deere PT Land...
